592
OxygenOS 10.0.1 for the OnePlus 6 and 6T
  1. G_Muffadal_Umrethwala_Ue
    Cupcake Dec 8, 2019
  2. F1547244557668 , via OnePlus 6T Midnight Black , Dec 8, 2019 :
    so far it's all good. just updated my 6t today to android 10 and we'll see more in the next few days. i updated mine with oxygen updater. i followed the instructions that take the incremental update as mine is not rooted and just a regular 6t.
    my question is is the oxygen updater official and the update is exactly the same as the one you'll get from one plus settings update.
    for the next update do i have to use oxygen updater again or just the regular one from the settings?
  3. Niloy Nk
    Cupcake Dec 8, 2019
  4. Avaline
    Gingerbread Dec 8, 2019
    Avaline , via OnePlus 6T , Dec 8, 2019 :
    oxygen updater is not an official official app. as for you other questions, I do not know
    F1547244557668 likes this.
  5. Prasun_Saha_6T , via OnePlus 6T Midnight Black , Dec 8, 2019 :
    mine is working perfectly
  6. Sandipan_1703
    Cupcake Dec 8, 2019
    Sandipan_1703 , via OnePlus 6T , Dec 8, 2019 :
    we are not paying such a lot of money to disable the app by ourselves..In india no one will have a working gpay that is pre-installed..so oneplus should have uninstalled or disabled it before rolling the update.
  7. DeadPool171198
    Eclair Dec 8, 2019
    DeadPool171198 , via OnePlus 6 , Dec 8, 2019 :
    Enable Smart Content detection in Camera settings .....
    Now long press on any object in the scene to access google lens
    T1555229554744 likes this.
  8. Kytharsis
    Marshmallow Dec 8, 2019
    Kytharsis , Dec 8, 2019 :
    Long-press on the viewfinder.
  9. at0mixX
    at0mixX , via OnePlus 6T , Dec 8, 2019 :
    If you updated through oxygen updater, you'll still receive OTA updates as you normally would through OnePlus. No worries.
  10. adi1001
    adi1001 , via OnePlus 6T , Dec 8, 2019 :
    @OnePlus reduced overall sound volume of the device(oneplus 6t) in this update.......on android 9 i used to listen music on device speaker at 80% volume and it was insanely loud but now i raised volume to 100% then also i m not able to listen music(same music and music player with same settings which was on android 9) that loudly and notification volumes are also low.
    overall sound quality is increased but volume is decreased so much that we cannot able to listen notification tones also.
    fix it @OnePlus.....
    Love this update.
    there are still small bugs which i mentioned earlier yesterday in the thread, otherwise good update.
    thank u @OnePlus
  11. Huds_Davis
    Cupcake Dec 8, 2019
  12. Kytharsis
    Tagging them (they're not even an OP staff member) won't do you any good. If you really want devs to see your comment, submit it as feedback at https://forums.oneplus.com/feedback
  13. T1555229554744
    Cupcake Dec 8, 2019
    T1555229554744 , Dec 8, 2019 :
    ya it worked!! thanks.
  14. adi1001
    Kytharsis likes this.
  15. S1548871261743
    Cupcake Dec 8, 2019
    S1548871261743 , Dec 8, 2019 :
    Hello, post upgrade camera is getting crashed, and existing China apps like China Mobile, China Merchants Bank are not at all working.
    Also, Popup video calling option is not working properly for IMO.
  16. A1550944388200
    Cupcake Dec 8, 2019
    A1550944388200 , Dec 8, 2019 :
    nothing it's still the same no update received
  17. Kytharsis
    Constantly checking it won't make it come any quicker. You'll be notified when the update is available.
  18. malereddi
    Cupcake Dec 8, 2019
