593
OxygenOS 10.0.1 for the OnePlus 6 and 6T
  1. KarthikayanS
    Froyo Dec 8, 2019
  2. Buvdeep
    Cupcake Dec 8, 2019
    Buvdeep , Dec 8, 2019 :
    After OS10 update, Smart contect detection option is not available in camera
    G_A.I.O_Viral_tnBG and rHITkM like this.
  3. rigih82219@mailt
    Cupcake Dec 8, 2019
  4. E1575820031404
    Cupcake Dec 8, 2019
  5. rHITkM
    Honeycomb Dec 8, 2019
    rHITkM , via OnePlus 6 , Dec 8, 2019 :
    Here Some bugs that I encountered in Android 10 are -
    1) • ANDROID 9 PIE had 9GB of storage as system storage and it never changed for a whole year until I received the ANDROID 10 OTA and then algorithm change drasticlly when i recieved the OTA I did not intall it for 2 days and I noticed that system storage rose up to 10 and then 11.Then I did the A10 installation, after updating the sytem storage was 11 GB. and I encountered below mentioned bugs so I performed FACTORY RESET and CLEAR CACHE, after this system storage took 14 GB of space. how is this even possible
    Attaching a SS of storage[e]1f447[/e]
    2) • Still no support for switching apps in landscape mode in Multi Window mode, if tried switching app orientation changes from landscape to portrait and its annoying.
    3) • Recent page layout looks IMBALANCE as app windows and closing apps Icon looks shifted upward and there is so much space at the bottom of the screen.
    Attaching SS [e]1f447[/e]
    4) • Screen flickering while adjusting the window size in multi window feature.
    5) • Slight delay while unlocking screen using face unlock.
    6) • Keyboard has extra space at the bottom of the screen.
    7) • Screen Recording Quality is very bad even on High Bit Rate , 60Hz Frame Rate , 1080 and 2160 Resolution.
    If I find more bugs I will inform you guys.
  6. F_Bill_HO_zCfh
    Donut Dec 8, 2019
  7. srajan.saxena
    Froyo Dec 8, 2019
    srajan.saxena , via OnePlus 6 , Dec 8, 2019 :
    go to camera settings.. enable smart content detection.
    then open camera and point to some object and press on the middle of screen
    Caomhin, Buvdeep and rHITkM like this.
  8. rHITkM
    Caomhin and Buvdeep like this.
  9. kundanaryakd
    Cupcake Dec 8, 2019
    kundanaryakd , via OnePlus 6T , Dec 8, 2019 :
    -Problem Facing
    *Battery is draining fast
    *Fingerprint issue not working fast
    *Ui is not smooth it's laggy
    overall Android Pie is most better so don't go for android 10.1 it's still buggy
  10. Deactivated User
    Dec 8, 2019
  11. rHITkM
    Please give it time. After few charge cycle it will get optimise automatically.
    Manjunath_sudheer likes this.
  12. G_Abhijeet_Bhattacharjee
    Cupcake Dec 8, 2019
  13. Buvdeep
    Cupcake Dec 8, 2019
    thank you, bro
    srajan.saxena likes this.
  14. cnaik91 likes this.
  15. Q1562607979035
    Cupcake Dec 8, 2019
    Raju5026 likes this.
  16. 0001ajaypanchal
    Cupcake Dec 8, 2019
  17. W1540197162853
    Donut Dec 8, 2019
  18. Fafkulec
    Cupcake Dec 8, 2019
    Fafkulec , via OnePlus 6 , Dec 8, 2019 :
    before update there were not empty space and there was no problem with gestures.
