592
OxygenOS 10.0.1 for the OnePlus 6 and 6T
  1. siddharth740
    Gingerbread Dec 8, 2019
    siddharth740 , via OnePlus 6 , Dec 8, 2019 :
    System Files Might be Big Don't Worry About the lag it will be stable after some days new major update takes time to settle. after some days i guess your phone will work Fine as before I m on Android 9 and my system is using 9.1GB on my OnePlus 6 Waiting For the update.
  2. Bayuputra4
    Donut Dec 8, 2019
    Bayuputra4 , via OnePlus 6T , Dec 8, 2019 :
    after a week usage OOS 10.1 i have found some buggy on performance, for somehow lag on recent app and gaming like PUBG. pliss fix this bug for perfomance experience
  3. rishworld2050
    Cupcake Dec 8, 2019
    rishworld2050 , Dec 8, 2019 :
    Worst update ever. Here are the few highlights:
    1. Sound settings are screwed up and the settings window is crashing.
    2. There will be no ringtone or vibration for calls so the phone must always be in front of eyes if you don't wanna miss a call. Due to first issue of sounds setting hang you won't be able to change this setting.
    3. Google play is crashing every time and unable to install anything. Google apps also started crashing.
    4. Once the settings window starts crashing has to restart phone every time otherwise the phone is becoming slow.
    5. Unable to access data like images, videos, documents after the update.
    6. Unable to rollback too since i am not able to download anything on this device and can't take backup since it is not showing in PC as well after the update
    PLEASE PROVIDE A FIX OR ROLLBACK ASAP
  4. Boubaker01
    Boubaker01 , via OnePlus 6 , Dec 8, 2019 :
    yes, this is my problem too
    Bayuputra4 and rishworld2050 like this.
  5. Farrukh Khan
    Cupcake Dec 8, 2019
  6. Ajay_Rajput_2411
    Cupcake Dec 8, 2019
  7. Kislay55_2
    Kislay55_2 , Dec 8, 2019 :
    Ha ha... I guess uhh r right. Ohk so lemme list out all d issues n. Uhh guess do let me knw if uhh r facing the same.
    1. That wide gap jst below the keyboard.
    2. When uh tap to open an app which is locked by app locker but just return to homepage without opening that app. The fingerprint icon remains on the screen for 2 to 3 seconds. This is annoying.
    3. The volte icon won't show up on status bar. It will show up only when the notification toggle it pulled down.
    4. The fingerprint unlock works slower than before.
    5. Whatever optimization is done with 5ghz wifi it's not working well now. If I jst pickup my phone n turn on wifi the wifi will connect but the internet won't work. So I need to turn on data first n then switch back again to wifi to make it work normally. This wifi issue is really really disturbing me.
    6. The digital well being option and the Google settings options many a times suddenly disappears from the settings app.
    7. If I listen songs on jio eaavn app, the next track won't play. Nor automatically nor manually. This is the optimization problem with the app.
    Guess do let me knw of u face any of these issues in Oxygen OS 10.0.1 update or all of them. These bugs seriously needs to be fixed.
    Rest everything works super smooth.
  8. Boubaker01
  9. Boubaker01
  10. Sanjiv06
    Cupcake Dec 8, 2019
    Sanjiv06 , Dec 8, 2019 :
    I am facing connectivity issues (both Data and calling) after the update. Rest all seems to be working fine as of now..
    ppavan1 and Kislay55_2 like this.
  11. Boubaker01
  12. adi1001
    adi1001 , via OnePlus 6T , Dec 8, 2019 :
    look at mine........but there lots of bugs like animation lag, response time is high and processing time is also high, laggy , animations are not smooth, animations are laggy like lossing fps , no animations for notification action for mail whatsapp etc. apps, apps not running in background like truecaller which is used for identification of unknown no while incoming call is coming, huwai health app is also not running in background which frequently disconnect my honor band 4 from device for continuous running of apps like truecaller, huwai health i have to set that apps to "don't optimise". and system memory is 14gb consumed .
    gaming is laggy and stucks for 1 second frequently and frame drops are happening.
    wifi is connection is poor, connects disconnects randomly and frequently.
    in short there so much lags, smoothness and speed of the rom is too less which less than android 9......
    android 9 was far better and best than android oxygen os 10
    they need to fix it so much bugs.
    like android 9 it will take time to get stable if oneplus provide regular update with bug fixes and performance improvements with updated security patches.
    Oxygen os 10 for oneplus 6t is not that much stable like 9.0.17.
    rishworld2050 and Kislay55_2 like this.
  13. Kislay55_2
    Try to reset data preferences in settings. It will help
    shijopj2014 likes this.
  14. Boubaker01
  15. Kislay55_2
    Uh. R very right brother. I support uhh. Specially this wifi issue I m facing keeps me so disturbing.
    adi1001 likes this.
  16. Z1529244877618
    Cupcake Dec 8, 2019
    Z1529244877618 , Dec 8, 2019 :
    Waiting,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
  17. Boubaker01
  18. Sharry7
    Ice Cream Sandwich Dec 8, 2019
    Sharry7 , via OnePlus 6 , Dec 8, 2019 :
    Try clearing cache from recovery.
    adi1001 likes this.
  19. adi1001
    done already...even i did a factory reset after update....still issues are there
