595
OxygenOS 10.0.1 for the OnePlus 6 and 6T
  1. NikhilRa
    Cupcake Dec 5, 2019
    NikhilRa , via OnePlus 6 , Dec 5, 2019 :
    kk .if u would anything about it plzz reply me
  2. Yash khemani
    Cupcake Dec 5, 2019
  3. TurzoZahid
    Eclair Dec 5, 2019
    TurzoZahid , via OnePlus 6 , Dec 5, 2019 :
    This method worked for me. As the MAC address has been changed after the update, you have to update the new MAC address with your router if the the router has MAC filtering turned on. There is no other way to work with.
  4. Deactivated User
    Dec 5, 2019
  5. Liehjan
    Marshmallow Dec 5, 2019
    Liehjan , Dec 5, 2019 :
    L33t Pau likes this.
  6. Maaz.saif
    Froyo Dec 5, 2019
    Maaz.saif , via OnePlus 6 , Dec 5, 2019 :
    did a factory reset and everything working fine . it seems that u didn't get the update. aww now don't cry
  7. TurzoZahid
    Eclair Dec 5, 2019
  8. saivychawla
    Froyo Dec 5, 2019
    saivychawla , via OnePlus 6 , Dec 5, 2019 :
    very buggy update, few bugs i have noticed
    1) status bar become black on black background
    2) gestures are buggy
    3) ringtone issue, different ring tone sometine on call.
  9. Yash khemani
    Cupcake Dec 5, 2019
  10. _Dragon_Master_
    Cupcake Dec 5, 2019
    _Dragon_Master_ , Dec 5, 2019 :
    ok thanks.
    i guess i have to roll back to pie 9.0.17 there is no other way.
    TurzoZahid likes this.
  11. Scherpenseel
    KitKat Dec 5, 2019
    Scherpenseel , Dec 5, 2019 :
    Batterij heeft altijd een aantal cyclussen nodig om te wennen aan de nieuwe software en jouw gebruik. Geef het aan aantal laad cyclussen en kijk dan nog een keer! De levensduur is best goed bij deze update.
  12. A1575540692850
    Cupcake Dec 5, 2019
  13. Kuncheymanideep
    Froyo Dec 5, 2019
    MALU8484 likes this.
  14. eliamarisio
    Gingerbread Dec 5, 2019
    eliamarisio , Dec 5, 2019 :
    For users who have already installed 10.1:
    1) Does Qualcomm® aptX™ HD Audio work on OnePlus Bullets Wireless 2?
    2) Could anyone send a screenshot of the settings menu item called "Sound quality improvement" or similar, where all preset equalizations are stored.
    Thanks in advance :)
  15. bvsaijanardhana
    Eclair Dec 5, 2019
  16. SHREYASADSULE
    Eclair Dec 5, 2019
  17. Maaz.saif
    Froyo Dec 5, 2019
    updated already. working fine for me
  18. MDBARROS
    Cupcake Dec 5, 2019
    MDBARROS , Dec 5, 2019 :
    Oficial version. I have alot work for downgrade it first time. Now I will have to do again. ONEPLUS changed alot for bad of coz.
    Vijay Raju 8888 likes this.
  19. Meet_GrimReaper
    Meet_GrimReaper , Dec 5, 2019 :
    Finally Post One plus has release the slight Buggy OTA saying 1801 MB for which I'm Happy and I've update the Device.
    Let me Tell the Pro of the new A10 So smooth and No LAG found Across and performance is awesome,
    1. A10.0.1 Great,
    2. Security Patch is of Oct'19.
    3. Camera Version 3.8.75
    4. Launcher is 4.0 post updating from play store 4.1.1 ( Step Tracker is added)
    5. Full Notch is still not working.
    6. Digital Well being added
    7. Hidden space has new Gesture which I Loved it (Trick is in Launcher settings)
    8. Check the restart time its 26 Sec approx (Not opted Boot option)
    9. Now WIFI 5 Ghz can be access with Scanner/ bar code which was need upmost.
    10. G cam is now working on 6t but can use OP7t Gcam working fine.
    End result so far so good.
    Now Cons:-
    1. All wanted Dark mode which is in needed so One plus has 3 option if you a Fan of DARK mode go to settings :- Customization :- Present Theme :- Nudanced Theme (dark Theme), Now if you set it and wanted to go to Normal Mode, the custom setting will be rested every time you change the theme and next 2 min need to spent to change from wallpaper - Icons - Color - Shape - fonts which I guess is a Bug.
    2. There are 12 color which are available to opt but if you change the color all goes to black and no name will be visible (its a Bug )
    3. Camera has improved but google Lens is not available.
    4. if you force Dark mode then 3rd part apps will not give dark rather Nasty blur looks (WhatsApp, Facebook,)
    5. Default Dark mode working on all google apps and Instagram and Play store which is most Clear dark.
    6 Standby :- amazing in 3 hr 1% dropped
    7 Battery :- Need to work as drain interval compared from playing PUBG with Smooth Extreme Graphic for 22 min with 100% charge it dropped to 77% which is really bad (all Apps are in Optimize mode).
    8. Phone Sound has Improved but Earphone mode not working to change setting.
    Rest i guess i as us all update.
    WhatsApp Image 2019-12-05 at 3.03.49 PM (8).jpeg WhatsApp Image 2019-12-05 at 3.03.49 PM (5).jpeg WhatsApp Image 2019-12-05 at 3.03.49 PM (4).jpeg WhatsApp Image 2019-12-05 at 3.03.49 PM (6).jpeg WhatsApp Image 2019-12-05 at 3.03.49 PM (5).jpeg WhatsApp Image 2019-12-05 at 3.03.49 PM (8).jpeg
