594
OxygenOS 10.0.1 for the OnePlus 6 and 6T
  1. AbhiPatel6896
    Gingerbread Dec 12, 2019
    AbhiPatel6896 , Dec 12, 2019 :
    try few things if not done..
    1- Wipe data and cache.
    2- wait for few days to let the update settle and maybe battery may improve if that's the reason.
    3- else do 1st step and then try calibrating battery manually. you can search in google on how to calibrate battery.
    please let me know if any of this helps you.. thanks brother [e]1f609[/e]
    Devyanshu sethi likes this.
  2. Avaline
    Avaline , via OnePlus 6T , Dec 12, 2019 :
    if there's no update, explain how people are getting the ota? there is an update. it's just over time more and more people get it. stop being impatient and stop throwing around wild accusations
    emptystreets130, ironass and Auristic like this.
  3. keshav9416067455
    Cupcake Dec 12, 2019
    keshav9416067455 , Dec 12, 2019 :
    still I have not received in my phone OnePlus 6t
    this is not fair OnePlus those who have one plus 6 they will receive the updated but why we are still waiting
  4. S1541519769593
    S1541519769593 , via OnePlus 6T , Dec 12, 2019 :
    once logout from your Gmail id and login again
  5. Avaline
    you are a bit rude if you think this is the best way to reply to someone saying they'd rather update through official means than some third party work around
  6. Auristic
    KitKat Dec 12, 2019
    Auristic , Dec 12, 2019 :
    Read Post #1 and try to understand what a staged rollout is (if you don't, re-read Post #1 until you do...)
    ironass likes this.
  7. Devyanshu sethi
    Donut Dec 12, 2019
    Devyanshu sethi , via OnePlus 6 , Dec 12, 2019 :
    thankyou brother. i will be trying all of these and will revert once done.[e]263a[/e]️
    M1573580829161 likes this.
  8. AbhiPatel6896
    yep sure man. best of luck[e]263a[/e]️[e]2764[/e]️
  9. H1576166545978
    Raju5026 likes this.
  10. A1560846606830
    Ting Chen likes this.
  11. satwikraman
  12. Kuncheymanideep
    Froyo Dec 12, 2019
    Kuncheymanideep , via OnePlus 6 , Dec 12, 2019 :
    arey bro every buddy knows that it's just an enthusiastic questionable question to ask that's it chill
  13. AmmonV
    Donut Dec 12, 2019
    AmmonV , via OnePlus 6 , Dec 12, 2019 :
    i have done that
  14. AbhiPatel6896
    uninstall outlook.. and then reinstall it.. hope that helps..
  15. andrew_maz
  16. alansangeeth
  17. adarsha_g
    Donut Dec 12, 2019
  18. Raghu2706
    Honeycomb Dec 12, 2019
    Raghu2706 , via OnePlus 6 , Dec 12, 2019 :
    Auxqii
    3 options.
    1) Wait more to get OTA.
    2) Use third party app called Oxygen Updater and force it via their servers.
    3) Use third party VPN set to Germany and get it via OTA.​
    Update is not region based, it's based on IMEI.. so VPN won't work.
  19. Aneel.mssd
    Eclair Dec 12, 2019
    Aneel.mssd , Dec 12, 2019 :
    try removing your fingerprint then add it but when ur adding it apply your fingerprint in a dim room with somewhat no light. As the in screen fingerprint sensor is a light detector so it's more accurate to enter ur fingerprint details in low light conditions. Hope this works!
    KVT_BK and Caomhin like this.
  20. F_Mohit_Gupta_FXOd
