594
OxygenOS 10.0.1 for the OnePlus 6 and 6T
  1. stupidaakash , via OnePlus 6 Silk White , Dec 16, 2019 :
    not necessary as the alternative method pickups uo the same file which you get from ota , you might have not extensively used you phone so you are not getting any bugs wait for a while you will get to know
    M1573580829161 likes this.
  2. T0mT
    Cupcake Dec 16, 2019
    T0mT , via OnePlus 6 , Dec 16, 2019 :
    beta 31 seems to have issues casting.
    Used to be able to cast to Roku stick but it's no longer picking it up. Since the beta 31 update stability and audio/visual synching isn't as good as it has been in the past using a MS wireless V2 adapter.
  3. SUNNYVERMA24
    Donut Dec 16, 2019
    Raju5026 and Shay+ like this.
  4. D1545483860499
  5. Alex1681
    Gingerbread Dec 16, 2019
    Shay+ likes this.
  6. jitenvithlani
    Shay+ likes this.
  7. Chaithunya
  8. drl431
    Marshmallow Dec 16, 2019
    drl431 , Dec 16, 2019 :
    Beta testers should be using the pinned open beta thread.
    Caomhin and Artemus. like this.
  9. Kaushal khandal
    Kaushal khandal , via OnePlus 6 , Dec 16, 2019 :
    hey guys ,i m suffering from some problems with my OP6 actually after i received the Android 10 update,my cell has started hanging and screen lickering. sometimes my camera got hanged and sometimes the screen got crazy .
    HELP ME
  10. Kaushal khandal
    keep patience bro, it will come after some time.
    and if you want it now you can download the app "Oxygen updater" app from play store and can easily get the latest update.
  11. H1537708398639
  12. AbhiPatel6896
    AbhiPatel6896 , Dec 16, 2019 :
    anytime brother [e]1f609[/e][e]2764[/e]️
    Caomhin likes this.
  13. Chaithunya
    Chaithunya , Dec 16, 2019 :
    thank you bro[e]1f64f[/e]
    Kaushal khandal likes this.
  14. AbhiPatel6896
    using since a week.. and you will be very shocked to see my phone's battery performance.. here i am attaching screen shots.. watch it.. I didn't faced any bug yet.. it's still the matter of patience man.. some apps maybe using power who aren't android 10 compatible.. some settings also would be affecting the performance.. no one can judge what's wrong.. but seeing my device's performance, i can say OnePlus has done a great job..
    Caomhin likes this.
  15. DarKrypton
    Eclair Dec 16, 2019
    DarKrypton , via OnePlus 6 , Dec 16, 2019 :
    Hello people. For those who are facing a lot of battery drain in OnePlus 6 after the update. Please try this trick to calibrate battery. Just charge phone till 100% and let it charge more for more 1-2hrs, and reboot. And then use it normal till phone gets switch off by it's own. Then charge it normally again and use it by your daily use. It worked for me. Should work for you guys too. Hope this helps. Thank you. Keep supporting OnePlus team and their work to get us more good updates.
    Caomhin, Alex1681 and M1573580829161 like this.
  16. T1572914198343
    T1572914198343 , Dec 16, 2019 :
    no security updates or Android 10 updates for my TMobile 6t. thinking it's time to switch phones. there seem to be no answers as to if this is ever going to come.
  17. F1560702442714
  18. Y1555970483689
    Eclair Dec 16, 2019
    Y1555970483689 , Dec 16, 2019 :
    is this how it supposed to work ? I can't believe ur expert mind? somebody might not need to fix issue anymore.
  19. Raju5026 likes this.
  20. A1531819170690
    Donut Dec 16, 2019
