595
OxygenOS 10.0.1 for the OnePlus 6 and 6T
  1. SurajSRK123
    Cupcake Dec 5, 2019
    F_Abhishek_Singh_wKkC likes this.
  2. B1560934785832
    Cupcake Dec 5, 2019
  3. V1558154985755
    Donut Dec 5, 2019
    N1527810086187 likes this.
  4. Cristi19
    Cupcake Dec 5, 2019
  5. M1555949504567
    Eclair Dec 5, 2019
    M1555949504567 , via OnePlus 6T , Dec 5, 2019 :
    would rply comments which are sensible to reply🤗
  6. L1563884954301
    Eclair Dec 5, 2019
    VY0REL 87 likes this.
  7. Tarun Singhi
    Cupcake Dec 5, 2019
  8. B1569478441122
    Cupcake Dec 5, 2019
    Sumanthnandeti likes this.
  9. B_Wrath
    Nougat Dec 5, 2019
    B_Wrath , Dec 5, 2019 :
    What? Can't you loads of people getting it?
    It's a staged rollout. Wait.
    L33t Pau likes this.
  10. Funk Wizard
    Moderator Moderator Dec 5, 2019
    Funk Wizard , Dec 5, 2019 :
    Alright, for all those who cant wait, sharing the full zip download links for the rollout 10.0.1
    OnePlus 6T OxygenOS 10.0.1 Full Zip
    Official
    MD5: 53cbd7fb9eb944d16ad1c27fccccd317
    OnePlus 6 OxygenOS 10.0.1 Full Zip
    Official
    MD5: 13d7f3c6a42d0c3fbe912beb5aa17e9f
    Flashing Instructions
    Download the necessary files from the above and follow as below:
    1. Download the Full Zip from above link and move it from the Download folder to the root of your internal storage.
    2. Navigate to Settings > System Update > Settings > Local upgrade > Select latest OOS Full Zip
    3. Flash the Full Zip
    4. Reboot System and Profit [​IMG]
    Device will reboot and your OnePlus 6T/6 is now running on the latest OxygenOS Firmware & OS based on Android 10
    The first boot may take some time so keep calm :)
    Warning: Do not flash partial update OTAs (under 1 GB) on a modified device! If you want to use partial OTAs, you must first flash a Full Zip that it applies to, and then flash the partial OTA from stock recovery. Flashing partial OTAs from TWRP will either fail or soft brick your device. You can return to a usable state by flashing one of the above full zips in recovery.
    Thank you for your patience and continued support,
    Funk Wizard
    Forum Moderator
    ironass, dam76, Kono14 and 41 others like this.
  11. L1563884954301
    Eclair Dec 5, 2019
  12. Jainkrish62
    Cupcake Dec 5, 2019
    Jainkrish62 , Dec 5, 2019 :
    I have an issue while uploading video stories on instagram. I am not able to upload video stories for more then 15 sec and this is the problem of Oneplus only.
  13. B_Wrath
    Nougat Dec 5, 2019
    Is this step still valid on A/B partition devices?
    Which partition is getting accessed while we wipe cache from recovery?
    ironass, drl431 and TheAyushJain like this.
  14. guywong
    Froyo Dec 5, 2019
  15. Sheikh_Rafiq_
    Gingerbread Dec 5, 2019
  16. A1518064584786
    Cupcake Dec 5, 2019
  17. Funk Wizard
    Its an optional step, dont have the 6 series devices anymore so cant test but this still works on my 7T series so should work the same backwards.
    ironass likes this.
  18. L1563884954301
    Eclair Dec 5, 2019
  19. furkhanalii
