595
OxygenOS 10.0.1 for the OnePlus 6 and 6T
  1. C1545443573678
    Cupcake Dec 6, 2019
  2. Vaibhav_Malabade
    Gingerbread Dec 6, 2019
    Vaibhav_Malabade , Dec 6, 2019 :
    Thats a feature, it supposedly allows easier typing.
  3. Mayur3006
    Cupcake Dec 6, 2019
  4. kvladan
    Froyo Dec 6, 2019
    kvladan , via OnePlus 6T , Dec 6, 2019 :
    I don't receive update. I am still on 9.0.17, Android security patch level : 1. Avgust 2019.
    I am from Serbia and I want to know when I receive new update?
    Best Regards
  5. samviper96
    Cupcake Dec 6, 2019
    samviper96 , Dec 6, 2019 :
    i don't think so i have noticed in oneplus7t it's normal
  6. Chirag1plus
    Cupcake Dec 6, 2019
  7. G_Sagar_s.h_VOzk
    Cupcake Dec 6, 2019
  8. Chirag1plus
    Cupcake Dec 6, 2019
    Chirag1plus , via OnePlus 6T , Dec 6, 2019 :
    can u suggest on digital clock, after update only analog pops up.
    changed the setting too but errrr not working
  9. sivaraman.sony@g
    Eclair Dec 6, 2019
  10. Dhayanand82
    Eclair Dec 6, 2019
  11. Subbu@1999
    Donut Dec 6, 2019
    Subbu@1999 , via OnePlus 6T , Dec 6, 2019 :
    Hai i update 10.0.1 Through local upgrade
    After any update getting through OTA Or Not
  12. Chirag1plus
    Cupcake Dec 6, 2019
  13. Vaibhav_Malabade
    If you are referring to space below keyboard, Then should be there for all devices running A10. Since the Gboard is a google app and not OPs.
    This will not be fixed anytime soon.
    If you wanna remove there are adb commands on google, Try searching.
    Caomhin likes this.
  14. Vaibhav_Malabade
    Yes, you will recieve future OTAs.
  15. Subbu@1999
    Donut Dec 6, 2019
  16. B_Wrath
    Nougat Dec 6, 2019
    B_Wrath , Dec 6, 2019 :
    You'll get ota. Don't worry.
    Caomhin likes this.
  17. @Kanouted10s
    @Kanouted10s , via OnePlus 6T , Dec 6, 2019 :
    If you install a VPN from Canada you receive the OTA. I did that.
  18. Old School
    Old School , via OnePlus 6 , Dec 6, 2019 :
    It has been rolled out in stages. Wait for a couple of days.
    Caomhin likes this.
  19. Subbu@1999
    Donut Dec 6, 2019
  20. Vaibhav_Malabade
    Yup there's a bug with the lock screen clock style, It gets reset to default setting i.e. digital to Analog. I have reported the bug in feedback section.
    Suggest you doing the same.
