660
  1. B k
    Ice Cream Sandwich Oct 13, 2019
  2. L1570984991748
    Cupcake Oct 13, 2019
  3. ravish5497
    Honeycomb Oct 13, 2019
  4. Kp anand preman
  5. SANATAN ROY
  6. L1570984991748
  7. rkgujar
    rkgujar , Oct 13, 2019 :
    when I will get upgraded Oxygen OS 10.0.1 for my OnePlus 7 device? please advise.
  8. Francesco_Capasso
    Donut Oct 13, 2019
  9. macnuss
  10. X1570985569194
  11. Noorulla07
  12. mdonnelly1127
    Froyo Oct 13, 2019
    mdonnelly1127 , via OnePlus 7 Pro , Oct 13, 2019 :
    so how do you install this and make this work?
  13. docnok63
    Jelly Bean Oct 13, 2019
    docnok63 , Oct 13, 2019 :
    I edited to add a link at the bottom. Once you have .xml in the right directory, double-tap to empty any area near bottom buttons to bring up config load screen. Load .xml twice to make sure it is loaded (app will momentarily restart...screen comes in from the right.) Change options if you want to then (16:9 instead of 4:3, etc)
    Edit: also adding link here
    https://www.celsoazevedo.com/files/android/google-camera/f/settings09/
  14. B k
    B k , via OnePlus 7 Pro , Oct 13, 2019 :
    thats cool..thanks
    will try now[e]1f601[/e][e]1f44d[/e]
    i will msg u if i have any problem
  15. VIJAY216
    VIJAY216 , Oct 13, 2019 :
    don't rush for it.its not worth
  16. G1561536826191 , via OnePlus 7 Pro , Oct 13, 2019 :
    Annoying bugs that I noticed after updating to Oxygen OS 10.0.1 (via OTA w/o VPN)
    1. Auto brightness sensor continuously changing display brightness & after unlocking the phone my brightness always goes to the least possible value.
    2. Facebook crashing
    3. Sound quality degraded
  17. G_Mike_Klug_RzpG
    G_Mike_Klug_RzpG , Oct 13, 2019 :
    Is this update more feature-rich than Open Beta 3? I am on Open Beta 3, but mostly interested in the camera fix.
  18. G_sugata_21
  19. shaikhisa39
    Eclair Oct 13, 2019
