658
  1. Vasilis15
    Cupcake Oct 13, 2019
  2. Wojtek_
    Gingerbread Oct 13, 2019
  3. PRATEEKV50
    Donut Oct 13, 2019
    PRATEEKV50 , Oct 13, 2019 :
    Things that can be improved :
    1. Fingerprint animation speed. It is improved as compared to 10.0 but android pie's was faster
    2. Ram management needs work.
    3. app opening animations aren't fast as android pie
    4. Ram boost seems to be not working. One point the lights are working and sometimes the lights are off.
    4. navigation gesture speed can be improved.
    5 space below the keyboard should be minimised and change in accordance with the colour of the app.
    6. smart display is useless. only displays music titles. more features can be added to it
    7. GPU performance can be optimised
    8. Also android 10 bought new icons for battery and wifi in statusbar. they should be a part of Oxygen os. doesn't make sense to leave them out.
    IN SHORT OXYGENOS10'S SPEED IS NOT GOOD. SPEED IS THE REASON PEOPLE BUY ONEPLUS DEVICES . HOPE THESE BUGS AND ADDONS CAN BE FIXED
  4. N1570995290052
  5. darkarvan
  6. nirbhaynikhil
  7. James 007
    Froyo Oct 13, 2019
    James 007 , via OnePlus 7 , Oct 13, 2019 :
    it's a beta version of 10.0.1 ur not missing anything my friend be happy that ur on 9/Pie just read comments wait for update 10.0.2 if not 10.0.3 untill u Will not see the update available to download on official 1+ website don't bother to install it.
  8. thanoskalk
  9. Georgeoneplus7pro
    Jelly Bean Oct 13, 2019
    Georgeoneplus7pro , Oct 13, 2019 :
    OnePlus should put you, fingerprint cartoons and naked women under the keyboard. So you didn't find any real problems.
    Colday_96, Darsh93 and Wojtek_ like this.
  10. Hersheyunited3
    Hersheyunited3 , via OnePlus 7 , Oct 13, 2019 :
    I am facing Heating issues and Battery Drainage issues since the update.
    Also my sleep timer is @ 15 seconds but the device is always awake and i have to manually double tap to close the screen.
  11. T1545303565029
  12. R1558647544511
    Donut Oct 13, 2019
  13. R1558204440047
  14. iulisimo
  15. Georgeoneplus7pro
  16. ShuvraC
    Eclair Oct 13, 2019
  17. Georgeoneplus7pro
    You are blind? I put the link above.
    G_Champa_Sama likes this.
  18. Wojtek_
    Wojtek_ , Oct 13, 2019 :
    Just a page or two ago, another guy asked the same question. Do you know how to Google by yourself? And why ask in OnePlus 7 forums? What kind of answer do you expect?
  19. Vasilis15
    Vasilis15 , Oct 13, 2019 :
    That's Greek language but the first letter is wrong! The problem is when i try to write this letter ...
    displays this"C". Check some screenshots...
