Hi OnePlus Team,
Today I've received Android 10 OTA update to my mobile. Thanks a lot for the update.
There are some bug's I found it..
1. Live wallpaper which is provided in Android 9 it's not working properly. it's showing like an normal image wallpaper there is no effect on it. Previously it's looking good, especially that effects.
2. There are some network lags is there while using WiFi. I've played Pubg in my mobile and I am using Act Fibernet with 150mbps speed. I've played with my friends on same network. They have not faced any issues. I've faced so many times lag, after taken this update.
3. Automatic brightness should have some improvements I think. In the evening it's automatically went low level while using mobile. It happened several times.
4. I've posted a bug already, like the Fitbit notification service is not working with OnePlus mobiles. Still I'm facing same issue on this update as well.
5. In India there is social app called Hike, it has private mode option and that is using lock options from security. I've enabled fingerprint to unlock the mode. While using that app, if I go private mode it's showing fingerprint reader to unlock the mode. Once I used it, fingerprint reader is not disabled/hidden. it's always displaying there, if I click on the same place fingerprint reader only showing up again and again. Unable to click on anything else in that place.
6. In OnePlus community app there is a option as reply to thread and it has comments box. there is no scroll inside the comments box..
7. Update logs says that, there is a option called Smart display. I've not seeing that option in my mobile.
8. I've a query here, What you mean by a brand new UI in update logs? I've not seeing any much difference on the UI. only thing is there are some customization features came and settings UI got some changes, other than that there is no more updates.
9. Security patch is from September release from Google after that, there is no update on this..
I've plan to set up my mobile newly by doing factory reset of my mobile and I will try to find more issues on this release and I will share in the comments.
Thank you.
