660
  1. Shreyas_St
    Froyo Oct 15, 2019
    Shreyas_St , via OnePlus 7 Pro , Oct 15, 2019 :
    You will receive the update...
    Or you can use oxygen updater
    Everybody is getting the OTA wait for few more hours
    S1558388618694 likes this.
  2. Cuddlesnake
    Eclair Oct 15, 2019
  3. S1558388618694
    Gingerbread Oct 15, 2019
    S1558388618694 , Oct 15, 2019 :
    Your choice lol, even though this is the stable version. Not everyone will have issues. I never had issues with 10.00.
  4. sahilrana
  5. Shreyas_St
    Froyo Oct 15, 2019
  6. Shreyas_St
    Froyo Oct 15, 2019
    Check your internet connection
    Force stop whatsapp and restart it
    Reboot youe device and try again
  7. Shreyas_St
    Froyo Oct 15, 2019
    Use oxygen updater or set vpn to india
    You will get jt
    Or wait for few more days
  8. Shreyas_St
    Froyo Oct 15, 2019
  9. Vihang Dasadia
    Donut Oct 15, 2019
  10. Shreyas_St
    Froyo Oct 15, 2019
  11. ravish5497
    Honeycomb Oct 15, 2019
    ravish5497 , via OnePlus 7 Pro , Oct 15, 2019 :
    i assume it is available for all oneplus devices in India now
  12. h4ck3e
    h4ck3e , Oct 15, 2019 :
    Well regarding the gesture animations and functioning.... Its so buggy that I almost regret upgrading to OOS 10 however regarding the battery life.... Go through a couple of charging cycles.... The battery performance will improve and its faring better than Pie
    IamMitesh likes this.
  13. ravish5497
    try using vpn and set it to Indian and you may get an update
  14. A_Sharma@DE
    Froyo Oct 15, 2019
    A_Sharma@DE , via OnePlus 7 , Oct 15, 2019 :
    @Manu J. is it possible that, as there are no notification led on OnePlus 7 there can something like OnePlus 7 Pro notification alert like colour on sides with slight pulsing of longer duration? Although it is fine as it is now, i think it won't be that bad if we have a notification alert system (other vibration and something like colour variations on screen). if the phone kept on silent mode that is when the such problems arrive. if possible then i would like to see it soon.
    Also if possible try adding new stock wallpapers on OnePlus 7 series.
  15. h4ck3e
    Well the 10.0.0 rollout was stopped preemptively however the 10.0.1 rollout has since begun. If u haven't gotten it already, expect to get it in a couple of days. I got mine yesterday.
  16. h4ck3e
    Hasn't the smart display been renamed as contextual display??
    Cuddlesnake likes this.
  17. beyondocean
  18. h4ck3e
    Just have some patience or u can always use oxygen updater and get the update right now.
  19. Madinashaik
    Cupcake Oct 15, 2019
  20. Cuddlesnake
    Eclair Oct 15, 2019
    Cuddlesnake , via OnePlus 7 Pro , Oct 15, 2019 :
    h4ck3e
    Hasn't the smart display been renamed as contextual display??​
    Maybe, no clue, however it used to show the weather above the fingerprint sensor,now its gone and i haven't changed any settings whatsoever. And above it states smart display.I ll play abit with it and get back with more info on the matter.
