660
  1. JNiemi
    Gingerbread Oct 17, 2019
    JNiemi , Oct 17, 2019 :
    You can try if you disable Google ARCore, sometimes it helps that screen brightness issue. If not just enable again and wait for real fix.
  2. James 007
    James 007 , via OnePlus 7 , Oct 17, 2019 :
    ladies and gentlemen's I received the update thru the OTA so far so good for now the finger print works same as on 9 no lag all seams to be fine ambient display is still present not like on others users at different name about the battery I can't say much as I did the update about half an hour ago time Wil show how this OOS will perform anyways I'm based in U.K if that helps.
    sarahmic likes this.
  3. AnkushMahe
    Froyo Oct 17, 2019
  4. mohdnazeeh
    Donut Oct 17, 2019
    mohdnazeeh , Oct 17, 2019 :
    Hey All,
    Upgraded to Oxygen 10.0.1 from 10.0 today, and noticed the below issues as in the previous version. Looks like they haven't been addressed.
    1. WiFi disconnects and reconnects every 10 minutes. I actually did time the disconnects over a video call and they were consistently being disconnected between 9-11 minutes.
    2. Slow fingerprint animations. At the launch event they did mention the fingerprint animations would be slowed down, for the fluidic animation to be visible. However looks like they tend to get a lot slow at times.
    3. Battery drain maybe a bit more than Oxygen 9.5.
    Please do let me know if anyone else is facing the same set of issues.
    I1565391570406 likes this.
  5. rajaji17 , via OnePlus 7 Pro Nebula Blue , Oct 17, 2019 :
    so many bug in this update... automatically mobile will going restart several times in a day.
  6. Daasty
    Honeycomb Oct 17, 2019
    truetotexas likes this.
  7. G1560928305867
    Eclair Oct 17, 2019
  8. Mayank Dhaka
    Froyo Oct 17, 2019
  9. vrkratheesh
    Cupcake Oct 17, 2019
  10. H1571333763792
  11. Nuga_Bogdan
  12. sohamsxc56
    Eclair Oct 17, 2019
    sohamsxc56 , Oct 17, 2019 :
    Guys report bugs, that's how future builds would become better. This is what the community is for.
    NOBODY CARES IF YOU HAVE RECEIVED THE UPDATE OR NOT! Stop posting update page screenshots.
    Give your feedback on the stability of the update!
    B k, os22244, g0dlike_ and 3 others like this.
  13. DTurnt_live
  14. JNiemi
    Settings -> System -> System Updates
    or​
    Just wait to phone inform you that there is update
  15. G_Deepchand_B_iAoJ
  16. ŁukaszDSW
    Donut Oct 17, 2019
    ŁukaszDSW , via OnePlus 7 Pro , Oct 17, 2019 :
    90Hz doesn't work - animations are smoother than at 60Hz. However, I set 90 Hz, turn on testufo.com and show 60 Hz. 90 Hz worked on Beta 3. Despite the lack of 90Hz, the battery holds the same as on beta3 or worse. If it wasn't for the fact that I had a problem with telephone connections on beta3 sometimes (I can't hear the caller) I would go back to beta3. I hope they improve battery life and 90Hz will be 90Hz again. best regards
  17. JNiemi
    Check this out
    https://forum.xda-developers.com/on...-force-90hz-app-game-uncaps-fps-t3940071/amp/
  18. emailuday
    emailuday , via OnePlus 7 , Oct 17, 2019 :
    Hi... Can I adjust screen ratio on new android 10 update on my #oneplus7?? I mean I don't want that notch display. Plz help. Thanks a ton in advance.
