660
  1. E1560964250224
    Cupcake Oct 18, 2019
  2. Satrajit Chakraborty
    Honeycomb Oct 18, 2019
    Satrajit Chakraborty , via OnePlus 7 , Oct 18, 2019 :
    Yes, and there is no such option to uninstall.Only thing you can do is to hide the same app which you want to.
  3. Satrajit Chakraborty
    Take a full backup, do a factory reset, and do a wipe cache.Hope it helps.
  4. P1541180587258 , via OnePlus 7 Pro Almond , Oct 18, 2019 :
    I knew the hiding option but just wanted to confirm. Thank you so much Satrajit. Also another thing I noticed , I see random files in the downloads folder. Even when you delete them they reappear. Did you observe this?
    Satrajit Chakraborty likes this.
  5. Shaddy007
    Donut Oct 18, 2019
    Shaddy007 , Oct 18, 2019 :
    finally got android 10.0.1 update
    android 10 is awesome
    system wide dark mode and Instagram dark mode and many more
  6. Satrajit Chakraborty
    There is no smart display in ambient display option and no chroma effect in reading mode as well.Looks like these are 7T series specific features. But it can be added later as they did for previous old models by adding the zen mode and screen recording feature.
  7. Emoisemo
    Froyo Oct 18, 2019
  8. Aman Choudhary 10
    Froyo Oct 18, 2019
    Aman Choudhary 10 , via OnePlus 7 , Oct 18, 2019 :
    Yes, why two file managers OnePlus? come on developers what the logic behind this?
    We don't need two file managers at least give option to uninstall the the new file manager!!
  9. Satrajit Chakraborty
    Till now didn't faced any such thing,if you are facing it I recommend to take a full bakup, do a factory reset and wipe cache.
  10. Satrajit Chakraborty
    It is looking good but it is not working properly.In some cases you will see color invert changes, no text visible and other problems as it is being forced to do so. It will get fixed only if the features get a compatible inbuilt option.
    Biswajit Padhi likes this.
  11. V1rTu
    Gingerbread Oct 18, 2019
  12. Biswajit Padhi
    Froyo Oct 18, 2019
    Biswajit Padhi , Oct 18, 2019 :
    I feel in performance wise Android 9.0 is better than 10.0.
    Device is getting slow after 10.0 update.
    Not a big improvement in camera section.
    Battery is dying faster.
    After updating to 10,Notch display setting is not present in display setting.
    Finger print sensor also not working properly...it is very slow now.
    In my opinion, before releasing new OS, one plus should check it properly if there is any major bug present or not.
    After one day use now ambient sensor also not working properly
    My suggestion to those who are not updating yet kindly wait some days for rectification of these bugs.
    V1rTu and F_Rishank_Gupta_QzKW like this.
  13. Shoeb4all
    Donut Oct 18, 2019
  14. Satrajit Chakraborty
    I haven't faced the same, do a factory reset and wipe cache memory while rebooting.
  15. Aastikahuja
    Donut Oct 18, 2019
    Aastikahuja , Oct 18, 2019 :
    hi when I want to share images from gallery, eg on WhatsApp they are inverted. this is after the update I received yesterday
  16. Satrajit Chakraborty
    It is working fine in my case.Haven't faced anything like that till now.
    Kozanostra likes this.
  17. Jayesh_Chettoor
  18. Mohsinmulla
    Eclair Oct 18, 2019
  19. F_Rishank_Gupta_QzKW
    Froyo Oct 18, 2019
    F_Rishank_Gupta_QzKW , Oct 18, 2019 :
    updated with oxygen updater. This version is buggy.
    screen freezed while using youtube.
    whatsapp giving black screen when sending images to someone.
    Also, screen going black after sometime when opening a video streaming website on chrome.
  20. M1571386037257
    M1571386037257 , Oct 18, 2019 :
    Hello, I've found a bug in OxygenOS 10.0.1. on the keyboard when in 'Navigation gestures (bottom)' mode there is a space where the navigation icon for the new (but unused in this mode) horizontal bar.
    See the space below the keyboard in the following picture.
    Shaddy007 and tolak like this.
