659
  1. ravish5497
    Honeycomb Oct 12, 2019
  2. F_Ken_Lin_AEIu
    Gingerbread Oct 12, 2019
  3. ravish5497
    ravish5497 , via OnePlus 7 Pro , Oct 12, 2019 :
    is this even a clean install ? what i was told is a lot different
  4. SCN4
    Cupcake Oct 12, 2019
  5. NILESH_KALBURGI_ONEPLUS3T
  6. SLYKER77
  7. S1541938376942 likes this.
  8. Swejuggalo
    KitKat Oct 12, 2019
    Swejuggalo , Oct 12, 2019 :
    But not a factory reset? Seems like a bug magnet you got. I've been on open beta on 7 Pro (gm1913) since first beta and haven't had anything else than minor flaws. I did a factory reset after OB1 and reinstalled everything manually with no kinds of backups used.
    Hopefully someone else got your issues and can replicate it and send in a bug rapport using the community app feedback tool.
  9. Swejuggalo
    KitKat Oct 12, 2019
    Yeah. That's the reason I changed to the Google version right away.
  10. Swejuggalo
    KitKat Oct 12, 2019
  11. G_Dhruv_Modi_FjGZ
  12. sechinov
    Ice Cream Sandwich Oct 12, 2019
    sechinov , via OnePlus 7 Pro , Oct 12, 2019 :
    VPN does not work, we are waiting. I really hope that the battery will be better. You can of course through the oxygen updater. But maybe I'll wait.
  13. Dharmik Siroya
    Eclair Oct 12, 2019
  14. G_Dhruv_Modi_FjGZ
  15. SLYKER77
    SLYKER77 , via OnePlus 7 Pro , Oct 12, 2019 :
    Not seen that. Any specific setting needs to be enabled / disabled? Already have it On.
  16. yiabol likes this.
  17. Swejuggalo
    KitKat Oct 12, 2019
    I do it after updating. Often recommended if doing major version upgrades. If 9->10 gives you issues try a reset before doing rollback and stuff
  18. Deactivated User
    Oct 12, 2019
