660
  1. G_Pavan_Naik_
    Cupcake Oct 18, 2019
    G_Pavan_Naik_ , Oct 18, 2019 :
    yes it is bad[e]1f620[/e]
    Biswajit Padhi likes this.
  2. Tedinetto
    Gingerbread Oct 18, 2019
  3. G_Pavan_Naik_
  4. Emoisemo
    Froyo Oct 18, 2019
  5. nunobjmj
    Eclair Oct 18, 2019
    nunobjmj , via OnePlus 7 Pro , Oct 18, 2019 :
    Hi, I update yesterday and after update I make a wipes cache and data, for have a clean installation, and about that, solves any problem I can arrive. And it's works so good... [e]1f60a[/e]
    Netsky60 likes this.
  6. Satrajit Chakraborty
    Honeycomb Oct 18, 2019
    Satrajit Chakraborty , via OnePlus 7 , Oct 18, 2019 :
    There is no such option to change the animation speed of the fingerprint.
  7. Utpaljoshi1512
  8. W1570637147528
  9. Y1569675772066
  10. docnok63
    Jelly Bean Oct 18, 2019
    docnok63 , Oct 18, 2019 :
    No, never in a Beta. Only 4K video recording in all three lenses in Open Beta 1. I ported this to OB2 and 10.0.0, but only wide. Can get 4K 30fps on wide angle and 4K 60 fps on main shooter in 10.0.1. Working on getting it all and combining into one modified apk.
    B k likes this.
  11. nunobjmj
    Eclair Oct 18, 2019
    For the moment all works fine. The battery, for me are a consommation normal, but it's soon. But I can say it's good for a new version Android. Of course, they are things to fixe and OnePlus need work much, to be perfect.
  12. abstruszero
    abstruszero , via OnePlus 7 Pro , Oct 18, 2019 :
    wait a few days so smart thing will learn your usage.
  13. X1559591116784
    X1559591116784 , Oct 18, 2019 :
    after updating a few things i noticed is that the screen output calibration has changed a bit. the display looks a bit different then before. the dark mode all around is highly appreciated. the only problem faced is the swiping feature. earlier we could swipe from the bottom left or right side to go back but now that doesnot work.insteaf we have to swipe gently from left or right corner of the screen which will take time getting used to. i even think that sound output has become wierd. suddenly the volume is very low and out of nowhere it becomes really loud. don't know what's happening. overall the update seems good.
  14. Tim628
    Eclair Oct 18, 2019
    Tim628 , Oct 18, 2019 :
    Here's my feedback
    Pros:
    Battery life is amazing after 2hrs and a half still got 75%
    Gestures are more fine tuned
    Screen calibration has improved in almost all profiles
    Camera has been improved when it comes to exposure and control of highlights
    Cons:
    Fingerprint animation is slower
    No option to set how long the ambient display stays on
    Too much Google apps that are not necessarily and are unable to be uninstalled
    Google services are somewhat privacy invasive by default and need to be toggled off manually
    No notification volume yet
  15. Lociaz
    Froyo Oct 18, 2019
    Lociaz , via OnePlus 7 , Oct 18, 2019 :
    yeah I'm with you!
    Venkatesh_thota likes this.
  16. X1571388491751
    X1571388491751 , Oct 18, 2019 :
    New operating system runs great,
    One small issue, compared to to oxygen 9 the lock screen unlock with the fingerprint is visibly slower. I believe this is because of the added animation. Is there a way to disable the animation to make the unlock speed as fast as it was before?
  17. Lociaz
    Froyo Oct 18, 2019
    I'm with you also!
    totally agree!
  18. beta3d10
    beta3d10 , via OnePlus 7 , Oct 18, 2019 :
    Finally got the update! Smart display is missing,as per One Plus they mentioned there will be Smart Display option.
    check out the screen shot.
  19. Jun_21
