658
  1. AlcatrazBlaze , via OnePlus 7 Mirror Red , Oct 18, 2019 :
    Hey thanks for being so polite and mindful of general etiquette in a forum and for helping me out with my problem.
    Never said there's any fault. Just asked what I was doing wrong. Thanks for guiding me, strong all-powerful thinker.
    It's the third screenshot, by the way
    Cheers, mate[e]1f48b[/e]
  2. DesiEscobarr
    Cupcake Oct 18, 2019
  3. pioneer_xx1
    pioneer_xx1 , Oct 18, 2019 :
    A want Oxygen 10 so. I'm from Czech republic and I have not any software upgrade alert. Did you know where was avilable new software in Czech republic ?
  4. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 18, 2019 :
    Some get great experiance with 10. Some of the most common issues seems to be a bad transition from 9.
    A factory reset with a minimal backup (only media files and perhaps sms/mms) seems to be the best way to get as a stable and good 10 as possible.
    For me doing that is a standard step when doing major version upgrades, but not all want to accept that as a solution.
    Some apps simply does not work good on 10 yet. So different users experiance can differ due to the apps is not fully adapted to 10 yet.
    Even Google themselfs has very similar experiences and problems on updated Pixel devices.
    Would be great if as many as possible use the feedback tool in the community app. The bug hunter search for bugs in the threads themselfs but can't of course catch and contact everyone writing something.
  5. clgon
    clgon , Oct 18, 2019 :
    I'm still trying to understand how the rollout is set.
    I haven't received the update.
    how I can know When to expect?
  6. E1561908775178
    E1561908775178 , via OnePlus 7 Pro , Oct 18, 2019 :
    Just updated the phone... Strangely... No change in UI/... No smart display option under Ambient light settings (atleast I couldn't find it)... Not sure if they've changed anything at all....
  7. mbcool
    Honeycomb Oct 18, 2019
    mbcool , via OnePlus 7 Pro , Oct 18, 2019 :
    After using it for couple of days i can surely say that there are bugs which are causing lags here and there in the UI apps like Spotify are also crashing
    UI doesn't feel snappier as it was on 9.0
    battery life also draneing
    Network speeds on wifi are slow
    Animation stuttering throughout the UI can be seen
    Hope that OnePlus releases a new update to fix these issue
  8. S1569004844808
  9. prad1382
    Froyo Oct 18, 2019
    prad1382 , via OnePlus 7 Pro , Oct 18, 2019 :
    Can anyone confirm the launcher after the upgrade. Apparently in my phone it installed Google launcher which is old and the latest pixel launcher is much better.
  10. K1560388607500
    K1560388607500 , Oct 18, 2019 :
    i noticed that the battery is draining to fast after upgrading. Previously i used to get screen on time 5 hours avg. but now it is not even close to 3 hours .. no new apps are installed and the usage is completely similar to before upgrade.
    anyone noticed the same problem?
  11. batmanfs
    batmanfs , Oct 18, 2019 :
    hi, this update made my phone unstable like (touch faulty,slow app opening,little bit lag, signal problems)
    V3X11 likes this.
  12. K1560388607500
    and also chorme is not working always. It is getting hanged most of the times...
  13. A1559734472994
    Eclair Oct 18, 2019
    A1559734472994 , Oct 18, 2019 :
    I found the bug .. I am still getting call from block number but while trying to pickup it's get disconnected immediately
  14. P1564395809114
  15. E1561908775178
    In fact.... After going through everything... Absolutely nothing has changed at all....its the same... No different look... No different features... NOTHING... Oh well
  16. P1564395809114
  17. D1558537038663
  18. Prashanth_Raj86
  19. G_BBall_KLHS
    Eclair Oct 18, 2019
    G_BBall_KLHS , via OnePlus 7 , Oct 18, 2019 :
    Should be , Android 10 sucks. Im not gonna upgrade till 10.0.03 gonna be realesed
