660
  1. Divyanshi Yadav
    Cupcake Oct 19, 2019
    Divyanshi Yadav , Oct 19, 2019 :
    Got the update but unable to apply it's features.
    Also now I have 2 Google pay not sure which one to use as both of them look entirely different
    98756454234546 likes this.
  2. U1562594447930
    Donut Oct 19, 2019
  3. O1564942882921
  4. DarpanReddy
    DarpanReddy , Oct 19, 2019 :
    After the update these things feel annoying.
    1.That awkward black bar below the keyboard.
    2.Fingerprint unlocking seems to be slow(it feels like the fingerprint unlock animation is slow).
    3.The customization in the settings needs to be made good looking.
    4.White colour border around Home button in Navigation gestures (left and right).
    That's all for now.Hope these things will be rectified.
    peace out[e]270c[/e]️.
    defcon012 and AnantDags like this.
  5. kanagaraj1010
    Ice Cream Sandwich Oct 19, 2019
    kanagaraj1010 , via OnePlus 7 Pro , Oct 19, 2019 :
    after 10.0.1 battery drains quick and SOT Is 5 hrs 50 mins only in my 7 pro device
    A1570336416720 likes this.
  6. AnantDags
    Gingerbread Oct 19, 2019
    AnantDags , via OnePlus 7 Pro , Oct 19, 2019 :
    Laggy animations, less responsivness!
    Hey all,
    I've just updated to android 10 and one of the most frustrating things I've noticed it everything feels less snappier compared to pie. When you try to complete one action you have to wait a little longer for it to complete before starting another like theres some lag in between them.
    For example :Whenever you are in an app or even in settings and you quickly try to swipe up to recent apps and the immediately try to swipe up once more on the present app to clear it, the phone doesn't recognize it and it goes back to homescreen instead of clearing the app. It works when you pause for a second after swiping up to recent apps but it used to be fast and immediate back on pie.
    Another one is back on pie when I used to minimize an app or close it and immediately tap on any other app on my homescreen which would trigger and open it but now it's like I have to wait for a second for the previous animation to complete and then I can do the next task. It doesn't work on the first try.
    This whole experience is really bad compared to how snappy it was on Android pie
  7. sujeetpatil111
    sujeetpatil111 , Oct 19, 2019 :
    can anyone please help me
    how to restore to android pie coz this version is full of bugs and app keeps crashing
    Z1571472364409 likes this.
  8. S1559488445607
    S1559488445607 , Oct 19, 2019 :
    is anyone facing issue of recieving notification?
    i am not getting the missed call notification, text messages notification sometime!
    what's the issue?
  9. Dinpai7
    Froyo Oct 19, 2019
  10. Emoisemo
    Froyo Oct 19, 2019
    Emoisemo , via OnePlus 7 Pro , Oct 19, 2019 :
    I suggest you to do factory reset and clear cache. But before that make sure to backup your phone. After that should be ok.
  11. Emoisemo
    Froyo Oct 19, 2019
    Yes.. That simple, for image gallery you can transfer all your image folder to your computer, thats it
    kevm66 and Areebanwar like this.
  12. B k
  13. Jay_Patel_247
    Jay_Patel_247 , Oct 19, 2019 :
    The game space concept is not that good according to me
    and OnePlus don't need to copy others.
    because of gamespace to activate fnatic mode we have scroll down notification bar or we have to turn it on by going first in game space and then we can start game from there.
    but if we directly start game only gaming mode gets on and
    we have to use notification bar for fnatic mode.
    but in older Android I think it was better when there was no game space but when you directly start game it gives you option to start fnatic mode on screen which becomes more comfortable.
    but in new version this thing is lacking.
    I hope OnePlus will give that option to turn on fnatic mode on screen because every time to use gamespace for starting game with fnatic mode or using notification bar can be hectic.
    But I believe on OnePlus that they will try their best to make it
    much more comfortable in new update.
    I also noticed that the option given of gaming mode which was in the notification bar along with wifi, Bluetooth,etc is not
    there and also it is not given in the edit mode.
    hope OnePlus will fix it, please......
    kevm66 likes this.
  14. Rahul0293
    Eclair Oct 19, 2019
    Rahul0293 , Oct 19, 2019 :
    Maybe you have to long press the notification and set preference for it that 'it is important or not important for you'.
    S1559488445607 and JNiemi like this.
  15. B k
    B k , via OnePlus 7 Pro , Oct 19, 2019 :
    clicked photos, while setting as dp, had problem on whatsapp. . was a bit lagging too.
    got an update for whatsapp on play store.
    now its fine. can set clicked camera photo as dp. no lagging
    anyone facing whatsapp problems should update and maybe it gets solved.
    thanks
  16. Y1570304296630
  17. defcon012
    kevm66 likes this.
  18. hananpeer
    Donut Oct 19, 2019
    hananpeer , Oct 19, 2019 :
    I don't understand the necessity of removing the notch hiding option from the display settings. Utterly disappointed with the new update because of that. Hope to see it back in the next update.
    kevm66 likes this.
  19. Areebanwar
    Honeycomb Oct 19, 2019
    Areebanwar , Oct 19, 2019 :
    Thank you!! :D
  20. pzkrolik
    Eclair Oct 19, 2019
    pzkrolik , via OnePlus 7 Pro , Oct 19, 2019 :
    is it normal for OnePlus to take sooo looong to fix major issues in new updates. Not to mention releasing an update which is a step back rather than improvement (battery life and camera quality downgrade, horizon light still not improved, screen still goes dark with no particular reason)
