660
  1. W1568807601792
    Cupcake Oct 19, 2019
  2. udeshvirk
    Honeycomb Oct 19, 2019
    udeshvirk , via OnePlus 7 , Oct 19, 2019 :
    Dont you have empty space in bottom area? I also use SwiftKey, but i am having this annoying empty space.
  3. Aditya_Sharma@DE
    Eclair Oct 19, 2019
    Aditya_Sharma@DE , via OnePlus 7 , Oct 19, 2019 :
    i got that as well, well one is the Google pay(Tez) and the other one was a Google Play Store pay and for such platform.
  4. mahpotnuru
    mahpotnuru , via OnePlus 7 , Oct 19, 2019 :
    after the update of new version which I recvd on 19.10.2019 one problem that I faced was auto lighting option which worked before the update but the same is stopped working now.
    pls look into the said feature .
    more problems haven't checked till now
    Mahesh
    (Please do not write phone number, edited by moderator)
  5. Aghilan2
    Aghilan2 , Oct 19, 2019 :
    Hide notch area not available in the display settings after the A10 update. Is there any chances of it coming back? or is there any other option to hide the notch?
  6. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 19, 2019 :
    I see alot of issues here and there. Not all but many things would probably be solved if you did a factory reset. It's highly recommend after a major version upgrade.
    But when you do so, keep the backup and restored data to the bare minimum (preferably just media files, sms/mms). I even refuse to let's Google restore anything during the setup process. It's not that hard to install a app manually. It's worth the time if you save time on troubleshooting bugs and stuff later on.
    If your problems have been huge before just install the basic stuff. Then add the extras later on in steps. Like a few apps per day or something.
    If any of the steps starts causing issues you have one of the apps in a specific step that could give you issues.
    And don't forget to use the feedback tool in the community app. The bug hunter search trough the thread but they don't catch exactly everything. Let's help them! [e]1f60a[/e]
    Divyanshi Yadav likes this.
  7. P1571496497237
    P1571496497237 , Oct 19, 2019 :
    I have today updated the 7 plus with new OxygenOS update ...now I am not able to edit the contact list. It's always giving me a message " you have disabled a required permission". Checked Apps settings ...all is enabled.... please help
  8. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 19, 2019 :
    It's filled with the keyboard theme. I also disabled the the bottom bar. Looks better and touching the empty space does nothing
    Johan Notte likes this.
  9. H1569908360308
  10. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 19, 2019 :
    Unless you see anything wrong with it for that app settings reset all app preferences
  11. Z1561405531758
    Donut Oct 19, 2019
    Z1561405531758 , Oct 19, 2019 :
    I am still facing some bugs:
    1. there is no smart display option.
    2. auto brightness sucks and reduces to lowest level.
    3. I am using power amp pro for music which keep on start and stop when playing on car Bluetooth.
    4. sometimes, touch is not responding while playing games.
    5. auto focus in camera is not working properly.
    these bugs I have noticed in 24 hours of usage.
  12. Taras K.
  13. H1569908360308
    H1569908360308 , via OnePlus 7 Pro , Oct 19, 2019 :
    Good update. Some issues:
    1. Slight stutter when using gestures and going home.
    2. Small delay and fade in after using fingerprint.
    3. App crashes/closes itself such as YouTube.
  14. sahirhussain
    B k and H1569908360308 like this.
  15. Cervantes
    Lollipop Moderator Oct 19, 2019
    Cervantes , Oct 19, 2019 :
    Hi
    Please, You read the first post update thread
    *"The update thread is a thread of questions and/or commentary"*
    Thread merged
  16. U1514893627764
    Donut Oct 19, 2019
  17. pjia143
  18. AhmedOman
    Donut Oct 19, 2019
    AhmedOman , Oct 19, 2019 :
    My banking app just said that you are registered in another device, I went through the activation of a new device and its working fine now. OP7.
  19. AhmedOman
    Donut Oct 19, 2019
    The application (Date on Status Bar) can no longer show the date in the status bar after the update.
    Any solution or alternative?
  20. P1571496497237
    Swejuggalo likes this.
