660
  1. preetham52
    Froyo Oct 19, 2019
  2. shahidraza7786
    Cupcake Oct 19, 2019
  3. B1570350511949
  4. O1570191845454
    O1570191845454 , Oct 19, 2019 :
    Since my last update my OnePlus 7 pro once shut down and restarted will not allow me to call out. I have to reset the phone so it erases last towers connected. once this is done and restarted it works again. Anyone know how to fix this I'm on Verizon here in Iowa USS
    wawanredblack likes this.
  5. Sanchitmeena
    Froyo Oct 19, 2019
    Sanchitmeena , via OnePlus 7 , Oct 19, 2019 :
    Guyzz please suggest something. I have updated my device two days back and still my one plus launcher didn't update to 4.1. If I check updates in Google Play Store then there is no update option. I have cleared the cache of Google Play Store but nothing happened.
  6. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 19, 2019
  7. Swejuggalo
    Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 19, 2019 :
    Devs can partially release apps on Google play too... Sure it's not a beta release?
  8. X1571497840225
    X1571497840225 , Oct 19, 2019 :
    Latest update received OxygenOS 10.0.1 and have some serious issue with it:
    1. While receiving SMS , it give direct option to open link containing in message which can be very fatal in cyber security point of view.
    2. As Notification Light is missing , so please release Horizon light option in OP7
  9. Kuberrohilla
    Kuberrohilla , Oct 19, 2019 :
    After the update, the vibration got turned on for double tap to wake even though i have turned it off under settings -> accessibility -> vibration and touch feedback -> touch vibration off
  10. C1559748323711
    C1559748323711 , Oct 19, 2019 :
    I need to use the pattern unlock feature twice since the update today,it doesn't work the first time.
  11. Sanchitmeena
    Froyo Oct 19, 2019
  12. Q1566410621245
  13. W1566059095793
  14. sridude1997
    sridude1997 , Oct 19, 2019 :
    i ve got a problem with this update !.i couldn't control my volume key when i watch a video ..its stuck and i couldnt make it high or low ...i find it very disturbing ,hope it has a solution apart from that oneplus is great with android 10
  15. forza83
    Donut Oct 19, 2019
  16. Fahad_Fadoo_Moten
  17. Punithan Appu
    Eclair Oct 19, 2019
  18. B1571500439457
    B1571500439457 , Oct 19, 2019 :
    when video calling in whatsapp, it seems to there's a bug. You can't open the whatsapp chat at all. It really is disturbing.
    And when video calling, is the display frequency turns down to 60 Hz? i've been using google duo and whatsapp and they most certainly turn down the refresh rate to 60 Hz. It'd be nice to have these issues fixed in the next update.
  19. srdic.tihomir , via OnePlus 7 Pro Mirror Gray , Oct 19, 2019 :
    Hello all, I have received the update day before yesterday, and i have to say, i have really no complaints...I have had a slight issue with third party app ringtones, Bluetooth not working correctly in my car, but then i just went through the whole settings, and revised all the ringtones, privacy settings, and permission settings...after that, i just restarted my phone, and now everything works perfectly... Even Android Auto and I had a lot of problems on OOS 9.... Battery is holding even better now, i had yesterday 4 h 15 min of screen on time with 70% battery...of course it depends on how you use your phone, but for me it's perfect.
    i haven't tried any of the games though...
    Cheers and god job One Plus!
