660
  1. sh_alharrasi
    Cupcake Oct 19, 2019
    sh_alharrasi , Oct 19, 2019 :
    just the circles keep on rounding and its getting very hot
  2. sayan7848
  3. JNiemi
    Gingerbread Oct 20, 2019
    JNiemi , via OnePlus 7 Pro Nebula Blue , Oct 20, 2019 :
    Turn off
    Setting -> Wifi -> Wifi Settings -> Choose Best Wi-Fi setting, just in case reboot.
  4. Korok Hidup
    Korok Hidup , via OnePlus 7 Mirror Red , Oct 20, 2019 :
    SajuMathew90
    The gesture for recent app behave bit odd. There is substantial wait time, when i draw the bottom bar up. it should be quicker. Its slow at home page.​
    Well, that's because of the Android 10 animation. Maybe you can try lower animation duration in the developer options.
    AnantDags likes this.
  5. R1571528248410
    Cupcake Oct 20, 2019
    R1571528248410 , Oct 20, 2019 :
    can I know the battery life for OnePlus 7pro on Android 10 compare to Android 9? thanks in advance
  6. X1567647822214
    X1567647822214 , Oct 20, 2019 :
    is anyone else when swiping on the home screen getting a touch sound when doing it twice quickly? I didn't have it in version 9 but for some reason when I swipe through 2 pages I get a touch sound?
  7. U1559821276371
  8. Georgeoneplus7pro
    Jelly Bean Oct 20, 2019
    Georgeoneplus7pro , Oct 20, 2019 :
    Press the power, volume+ and volume- buttons simultaneously and the phone will turn off. Try to start it after 10 minutes. Then press the power and volume- button and return to the factory settings.
  9. arfislam
  10. arfislam
  11. Sridharlovevirus
    Donut Oct 20, 2019
    Sridharlovevirus , Oct 20, 2019 :
    call of duty get hanging in new update. it's hanging and automatically closed. I'm using one plus 7 pro 8gb and 256gb.
  12. uk_ramprasad
  13. Citzen Z
    Citzen Z , Oct 20, 2019 :
    The update fixed some of my issues from 10.0.0: the gestures work more.predictable, beside this, I do not see any regression. The auto display brightness is a real mess, not really usable. most of the time the display gets adjusted way too dark.
  14. dcarlospc
    Donut Oct 20, 2019
    C1554535124922 likes this.
  15. vishu_vinay
  16. S1558388618694
    S1558388618694 , via OnePlus 7 Pro , Oct 20, 2019 :
    it's not oxygen updaters fault. I used it & no bugs at all. before there was, but when I did a factory reset after updating, all the bugs were completely gone. Same thing if you download the software update from XDA developers.
    vishal_breaksome likes this.
  17. G_Randy_Coghill_gOyr , via OnePlus 7 Pro , Oct 20, 2019 :
    I would like to go back to 10.0.0 as 10.0.1 I have issues with.
    1) the picture I have on my lock screen is now stretched, it was fine in 10.0
    2) I can no longer verbally speak a text MSG in my 2019 Honda Civic, it just says things like ok but will not let me speak my MSG. This is also a safety issue as you will get people manually putting in responses as voice isn't working.
    Alt
  18. I1564848344768
  19. Georgeoneplus7pro
    https://forums.oneplus.com/feedback
    Report the error here.
  20. Rizan.Diana
    Rizan.Diana , Oct 20, 2019 :
    There are a lot of bug after update. Notification alert some of them not shown. When go to data restriction, many apps icon not shown. And final some of the apps not compatible. Please fix it.
