660
  1. X1561138113184
    Donut Oct 20, 2019
  2. nen3i
    Honeycomb Oct 20, 2019
    nen3i , via OnePlus 7 , Oct 20, 2019 :
    navigation gestures need improvements.
    when using navigation gestures left and right the home button is not always responding to touches. sometimes you cannot switch from an app to another from the first try.
    other times when I'm using the gesture to switch from an app to another, after a few uses like this the app right next to the current app is an app that was used long time ago. they seem to be rearranged in other order
    sohamsxc56 likes this.
  3. H1571560564133
    Cupcake Oct 20, 2019
  4. sarahmic
    sarahmic , Oct 20, 2019 :
    Dear One Plus
    Fix the Battery drainage after this update please.
    It's the thing which makes us ALL angry !
    W1571547904827 and Vaghan like this.
  5. Amitg1433
    Amitg1433 , Oct 20, 2019 :
    I am using OnePlus 7, I got update yesterday and after I updated my phone hangs frequently. pls help me.
    W1571547904827 likes this.
  6. Cervantes
    Lollipop Moderator Oct 20, 2019
    Cervantes , Oct 20, 2019 :
    Hi
    Please, You read the first post
    *"The update or beta thread is a thread of questions and/or commentary"*
    Please, You can use the search engine before opening a new thread
    Thread merged
  7. Arnaud_Ieè
    Eclair Oct 20, 2019
    Arnaud_Ieè , Oct 20, 2019 :
    Theme keeps randomly resetting to light, I have to apply dark theme several times a day...
    Mariodew likes this.
  8. Bybba
  9. surajgupta07
    Donut Oct 20, 2019
    surajgupta07 , via OnePlus 7 , Oct 20, 2019 :
    how? help me i want to revert back to. sot is very less.
  10. sohamsxc56
    Eclair Oct 20, 2019
    sohamsxc56 , Oct 20, 2019 :
    I also noticed occasional stutter and lag during swiping up from bottom to go into multitask page. The swipe gesture doesn't always work reliably. The black bar at bottom of the keyboard is still there Back swipe gesture doesn't always work in portrait mode app, for example PUBG.
  11. Vaghan
    Vaghan , Oct 20, 2019 :
    You can use the ROM which was published for beta users to go back to Android 9. In my case I took my OP7 to service center to have the back glass replaced and I asked them to downgrade it and they did it.
  12. Swami88
    Swami88 , Oct 20, 2019 :
    how to revert to Android 9 ?
  13. pjia143
    pjia143 , via OnePlus 7 Pro , Oct 20, 2019 :
    so with my banking apps...not working
  14. U1514893627764
    Donut Oct 20, 2019
  15. Q1508302633756
    Q1508302633756 , via OnePlus 7 Pro , Oct 20, 2019 :
    i am facing issue after update.. A green circle is reflecting at fingertouch place on screen and not letting me pressing the icons besides that.. can you please provide the resolution.
  16. B1565804763674
    B1565804763674 , Oct 20, 2019 :
    please provide the camera customisation updates for oneplus 7pro to include capture video with all cams including wide angle, macro mode and other settings .
    kevm66 likes this.
  17. HK_47
  18. D1566310177432
    Donut Oct 20, 2019
  19. J1569746761801
    J1569746761801 , Oct 20, 2019 :
    hi,
    After installing the Android 10.0.1 update on my oneplus7, ringtone is not getting set up and it just giving a small 'ding' sound when call is coming,
    kindly help, all other notifications are functioning as normal as before.
