660
  1. A1551877830995
    Cupcake Oct 20, 2019
    A1551877830995 , Oct 20, 2019 :
    Display setting Auto not functioning properly. Either the display goes to too low or doesn't respond to adjustment.
    suneel_seelam likes this.
  2. S1567753150187
    S1567753150187 , Oct 20, 2019 :
    Issues i found in the update-
    1. My whatsapp is lagging and not working if whatsapp video call is working. I have to reject the call to text someone or else the phone hangs off.
    2. While playing call of duty it's lagging and crashing and sometimes the game is hanging too.
  3. HRG_Henry
    Froyo Oct 20, 2019
    HRG_Henry , Oct 20, 2019 :
    The Never Settle home screen in the left doesn't work anymore. I can't press any icon. I can only interract with settings button. How can they break this...
  4. suneel_seelam
    Eclair Oct 20, 2019
  5. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 20, 2019
    Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 20, 2019 :
    Looks like a collection you got.
    Sometimes it's just simpler to do a factory reset with a minimal backup. Like just media files and and avoid to restore data during the setup strange.
    Sometimes less is better. And it seems to improve the situation for many.
    It does not help with everything though.
    WhatsApp has a bug fixed in beta 3 for example. Should be there in next stable unless it's not already there. Some apps still suck in Android 10 regardless of brand so in some cases its up to the app developer.
    Before you do anything...
    Please use the feedback tool to report these issues. It exist within the community app.
    If they need more info they will contact you via PM.
    J1571466104765 likes this.
  6. Swejuggalo
    Parts of the screen does not respond? And it remains after a reboot?
  7. nunobjmj
    Eclair Oct 20, 2019
    nunobjmj , via OnePlus 7 Pro , Oct 20, 2019 :
    Ok. Can you tell me, who are the notifications enabled with horizon lights? Because I think the most importante are calls and messages missing, WhatsApp, messenger, Instagram and others equally. I not understand, why we want this horizon lights, if they don't make our job right...
    roma_cherepov likes this.
  8. Nic2112
    Ice Cream Sandwich Oct 20, 2019
    Nic2112 , via OnePlus 7 Pro , Oct 20, 2019 :
    It's in the notification settings for each app, the "Pop up on screen" needs to be enabled for Horizon lights to trigger.
  9. TheNamelss
    TheNamelss , via OnePlus 7 Pro , Oct 20, 2019 :
    Hello,
    is it just me or my OnePlus 7 Pro lights up slower when I unlock it using the fingerprint sensor, because of the new animation added after the Android 10 update?
    I'd like it more if I could disable that animation because, even if it makes the usage more gorgeous, it feels like it's slower than the old instant light up of the screen.
    If you could include an option where I can disable that, it would be awesome!
    Thanks!
  10. HRG_Henry
    Froyo Oct 20, 2019
    After restart, removing all items and another restart it started working.
    Swejuggalo likes this.
  11. arkhlam
    Eclair Oct 20, 2019
    J1508070026278 and nunobjmj like this.
  12. tokamak2077
    tokamak2077 , via OnePlus 7 Pro , Oct 20, 2019 :
    Get the Update to A10.01 this morning.
    No issues found til now.
    7Pro
    wirhout wipe or factory reset
    All Apps working Perfekt.
    BT and all Networks working perfekt.
    Normal battery draining.
    2 houers Display time and listening music 80% left.
    good Job so far !!!
    Big thanks oneplus.
    J1508070026278 likes this.
  13. abebiker
  14. surajgupta07
    Donut Oct 20, 2019
  15. abebiker
  16. nunobjmj
    Eclair Oct 20, 2019
    I trying and don't work. Thanks, but OnePlus, want works more to have a "Always on Display" like others marks. I like to much my OnePlus 7 pro, and I believe OnePlus will go far, but please listen with attention what wants your customers, because are they who makes OnePlus go farther.
  17. N1566150226464
  18. vasu.9866
    nunobjmj likes this.
  19. Rajaf220
    Rajaf220 , Oct 20, 2019 :
    ok bro
  20. Swejuggalo
    You could end up waiting forever though [e]1f609[/e] Always bugs reported. Keep in mind that those that come here are the ones with issues. How would you know how many that it actually works for? There is a huge unbalance between happy and unhappy users here. Because the happy ones are not here constantly talking about it [e]1f609[/e]
    Ofcource there is bugs. For some it simply works great and for some it sucks. So many variations possible. Some just need to put some effort in making a factory reset without all that backed up shit slapped on top.
    Some app developers has not yet made sure their apps work good on Android 10. Android 10 needs some time to mature and seems to be sensitive about backups, previously existing data and such. Clean is the way to go for minimal issues.
    Personally I'm on beta 3 and it feels near perfect for me. Minor things that I'm more than happy to report and it does not bother me. 212h without reboot and no app crashes or issues here.
    I don't use Android Auto so I can't verify myself. I'll gladly report issues and investigate it though. Send me a free car that supports it and I'm on it [e]1f609[/e]
    It seems like it's not being solved by factory reset nor beta version though. Needs a real fix there. Probably more verified issues hidden here and there that I can't think of right now.
