660
  1. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 20, 2019 :
    You could end up waiting forever though [e]1f609[/e] Always bugs reported. Keep in mind that those that come here are the ones with issues. How would you know how many that it actually works for? There is a huge unbalance between happy and unhappy users here. Because the happy ones are not here constantly talking about it [e]1f609[/e]
    Ofcource there is bugs. For some it simply works great and for some it sucks. So many variations possible. Some just need to put some effort in making a factory reset without all that backed up shit slapped on top.
    Some app developers has not yet made sure their apps work good on Android 10. Android 10 needs some time to mature and seems to be sensitive about backups, previously existing data and such. Clean is the way to go for minimal issues.
    Personally I'm on beta 3 and it feels near perfect for me. Minor things that I'm more than happy to report and it does not bother me. 212h without reboot and no app crashes or issues here.
    I don't use Android Auto so I can't verify myself. I'll gladly report issues and investigate it though. Send me a free car that supports it and I'm on it [e]1f609[/e]
    It seems like it's not being solved by factory reset nor beta version though. Needs a real fix there. Probably more verified issues hidden here and there that I can't think of right now.
  2. amolbb51
    Eclair Oct 20, 2019
    amolbb51 , Oct 20, 2019 :
    how to updrade from andriod 10 to 9 ... too many bugs are in android 10 . one plus team is seems to focusing on lunching new product instate of focusing on developing bug free os ... i think time to move on other product .
  3. suneel_seelam
    Eclair Oct 20, 2019
  4. N1520431260526
    Froyo Oct 20, 2019
  5. Challagulla Naveen
    Eclair Oct 20, 2019
    H1569908360308 likes this.
  6. C1571589521843
    Cupcake Oct 20, 2019
    C1571589521843 , Oct 20, 2019 :
    Sir
    upgrade of OS Android 10 is good but we found there is a bug
    we are having finger lock in screen display issue.
    if we started using app locker with finger lock facility
    then we are not able to use letter "V "
    the word over the finger scanner reader.
    it blocks all the function which falls on finger lock scanner area.
    Due to this issue we are not using finger lock for apps.
    2 of my friend mobile also faced same issue.
    we all are having one plus 7 pro ( 12gb + 256 gb memory )
    pls support us to clear this issue at the earliest.
    Thanks in advance.
  7. Demon_hunter
    Honeycomb Oct 20, 2019
    Demon_hunter , via OnePlus 7 Pro , Oct 20, 2019 :
    the future updates will enable the feature
  8. E1517769746768
  9. E1517769746768
    E1517769746768 , Oct 20, 2019 :
    Still doesn't work
  10. anujay.aditya
    Gingerbread Oct 20, 2019
  11. George Kampourakis
  12. N1567409977459
  13. C1571589521843
  14. DSC1985
    DSC1985 , via OnePlus 7 , Oct 20, 2019 :
    Hi sir, recently I upgraded to Android 10 in my OnePlus 7. But after upgradation some lags I have found.
    1) In-display finger print capture is slow compare to Android pie version.
    2) Bluetooth connection is having some issue when I played songs in my car.
    3) The option like Slow motion in camera - display not good.
    I want to know this problem is in my phone only or all are facing the same.
  15. Hi im Luki
    Hi im Luki , via OnePlus 7 Pro , Oct 20, 2019 :
    When I try to send Messages, I recognized a little white gap between keyboard and the phone. So the keyboard starts like 0,5cm above the start of the screen. Is it normal in Android 10? I use the new Left and Right Feature with the disabled gesture line. I think that there was no Gap in Android 9
  16. arsalan.aarib
    Eclair Oct 20, 2019
    J1508070026278 likes this.
  17. TommyHammy
    TommyHammy , Oct 20, 2019 :
    Great update. Working all fine for me. Cant see any bugs so far and battery seems the same.
  18. J1508070026278
    J1508070026278 , via OnePlus 7 , Oct 20, 2019 :
    very true.. i am one of the few happy users of android 10 update here it seems.. but there must be thousands like me who are not active on this forum.. so its not correct to mark an update as 'failed' on the basis of a handful of user issues reported on this forum
    Marcstang04 and Edobig like this.
  19. G_VINAYAK_PATIL_tfcX
    Eclair Oct 20, 2019
    G_VINAYAK_PATIL_tfcX , Oct 20, 2019 :
    another bug found while playing ping. all my controls are moved little bit inside and microphone and speaker. controls are moved behind map.
    does anyone also facing same issue?
