658
  1. KIRAN_G_PARMAR
    Cupcake Oct 21, 2019
    KIRAN_G_PARMAR , via OnePlus 7 , Oct 21, 2019 :
    Battery drainage issue and fast charging is also very low as compared to previous version.
    Performance also down.
    Not very good update...
    Test before rolling out stable updates
  2. RaGnaRokMUI
    Eclair Oct 21, 2019
    RaGnaRokMUI , via OnePlus 7 Pro , Oct 21, 2019 :
    I know it's a little annoying, but try to be patient, it's for your own good. Would you rather use a stable Android 10 or wanna face issues?
  3. O1509461389811
    O1509461389811 , Oct 21, 2019 :
    since I updated OS10 phone getting slow, face unlock not responding sometimes, screen not responding properly, touch not working can you please help me.
  4. G_BBall_KLHS
    Eclair Oct 21, 2019
    G_BBall_KLHS , via OnePlus 7 , Oct 21, 2019 :
    Downgrade to Pie. And do not update, if u see that all useres have a issues with 10.
  5. RaGnaRokMUI
    Eclair Oct 21, 2019
    man that's very childish of you to curse the whole brand over just an update issue, that's not an ideal behaviour. that's an update issue and that is why OnePlus is rolling out this version stagewise so that it can take note of any issues and solve them. cursing the whole community isn't going to solve anything. calm down and wait for the fixes.
  6. Sahil_lihas
    Gingerbread Oct 21, 2019
    RaGnaRokMUI likes this.
  7. RaGnaRokMUI
    Eclair Oct 21, 2019
    It looked weird to me too at first but now I'm adapted to that look :p
    I totally agree with you on your suggestion regarding being able to control which apps to enable dark mode.
    P1566382265066 likes this.
  8. Febul
  9. V1571645727983
    V1571645727983 , via OnePlus 7 , Oct 21, 2019 :
    Update problems
    current OS - OxygenOS 10.0.1
    Device : OnePlus 7
    1 : Gallery is not working
    2: camera application is not working
    3: Device is getting stuck
    4: Fingerprint sensor issue
    5: Hidden space is not responding
    V1rTu, sovuart and Sahil_lihas like this.
  10. akks
    Jelly Bean Oct 21, 2019
    akks , Oct 21, 2019 :
    Did you hard reset or atleast clear system cache, after update?
  11. RaGnaRokMUI
    Eclair Oct 21, 2019
    hi there,
    if you're using the full screen gestures, just swipe diagonally from either of the two bottom corners and it'll trigger the assistant. when you'll unlock your phone, you'll see in the bottom corners some sort of curves which tells you that they are for assistant function. Hope you find it helpful!
    Ozair Siddiqui likes this.
  12. V1571645727983
  13. RaGnaRokMUI
    Eclair Oct 21, 2019
    it's not optimised for Android 10, sadly!
    Sahil_lihas likes this.
  14. akks
    Gcam optimised for Android 10 is available to download for quiet sometime. Don't misguide.
  15. Alexey Zaytsev
    Eclair Oct 21, 2019
    Alexey Zaytsev , Oct 21, 2019 :
    Oneplus приобрел популярность и больше не выпускает качественные обновления. Теперь они забывают о предыдущих моделях и уделяют все внимание производству новых моделей. Сожалею, что купил OnePlus 7. До этого у меня был OnePlus 3t. Сначала они хорошо его поддерживали, но потом просто забыли о нем и целый год не могли выпустить для него обновление для Android 9. В результате ситуация была такой же, как с OnePlus 7. Теперь они обновляются в течение двух месяцев с ошибками 9.0,9.01,9.0.2, 9.0.3,9.04. Вот и все. Они оставили 9.0.4 с ошибками и больше не поддерживают этот телефон.
  16. RaGnaRokMUI
    Eclair Oct 21, 2019
  17. akks
    You should have
  18. RaGnaRokMUI
    Eclair Oct 21, 2019
    chill man! I'm not misguiding, I'm just saying that the version might not have been updated by that person that's why it wasn't working.
  19. S1540139289093
  20. m_senthil_1992
    m_senthil_1992 , via OnePlus 7 Pro , Oct 21, 2019 :
    what you have did that
