648
  1. Yamarrash
    Cupcake Oct 21, 2019
    Yamarrash , Oct 21, 2019 :
    It was implemented, they retire the button, even if I'm just saying that is necessary it was there.
  2. Dr.Profit
    Dr.Profit , Oct 21, 2019 :
    The Lag when scrolling between apps in the recent apps screen is killing the fluidity. Hopefully it gets optimised in the future updates
    cds.deep likes this.
  3. cds.deep
    Eclair Oct 21, 2019
    cds.deep , via OnePlus 7 Pro , Oct 21, 2019 :
    same issue.
  4. F1571668402475
    F1571668402475 , Oct 21, 2019 :
    Updated - But i think there is a bug.
    The ringtone only beeps - I tried changing the ringtone doesn't work. Very funny.
    OnePlus kindly put out a fix.
  5. Dr.Profit
    I would have loved if they kept the Oxygen OS gestures but added the Swipe bar at the bottom.
    I prefer the Swipe up from bottom to go back instead of swiping the left and right edge of the screen (feels weird with a case on my phone).
    However, I love the little bar thats at the bottom that allows you to switch between apps really quickly.
    Hopefully they make that an option in future updates.
  6. Rajat_latwal
  7. P1564936900262
    P1564936900262 , Oct 21, 2019 :
    after the update in my oneplus 7 pro, there are some bugs i found:
    1. problem with Bluetooth connection. it breaks sometimes i.e., don't share the data but the device says it's connected via i have to switch off Bluetooth for some time and then reconnect it for proper connection everytime
    2. no option of smart display available under ambient display in my settings.
    3. some apps like google pay demands force touch to launch.
    4. battery drains faster than android 9
    hope the team fixes it in next upgrade
  8. cdilworth
    Donut Oct 21, 2019
  9. B1571645983692
  10. J1508070026278
    Gingerbread Oct 21, 2019
    J1508070026278 , via OnePlus 7 , Oct 21, 2019 :
    Agreed that users shouldn't have to go through the hassle of doing a full factory reset in order to resolve issues occurring due to the update.. clearly Oneplus testing team didn't do a good job of thoroughly testing the update. I think maybe they just did a clean install on a new device and did the testing. They should have upgraded an Android 9 device to Android 10 and then should have tested thoroughly.
    Having said that though, at the moment the only quick fix to all the issues is to do a factory reset and do not restore any backup.. just sync contacts, messages, pictures etc to Google and then manually install all apps after the factory resetting.
    Painful way of solving issues i know, but this is the only way to fix the issues as of now until oneplus comes up with an easier solution.
  11. Dr.Profit
    Wait until they fix the bugs in the next update.
    I updated and I have a pretty ok experience but I must admit that currently Oxygen OS on Android Pie is more optimized.
    arameshc likes this.
  12. B1571668432094
    B1571668432094 , via OnePlus 7 Pro , Oct 21, 2019 :
    I'm having issues with Call of Duty and Pubg crashing while playing the games. Happens atleast twice per game that I have to close the app while I have nothing else open and restart it and rejoin the game. something is off in the gaming settings. please do check and let me know.
  13. Georgeoneplus7pro
    Jelly Bean Oct 21, 2019
    Georgeoneplus7pro , Oct 21, 2019 :
    Maybe the errors of the 7 series phones will be fixed. But we paid a lot of money on phones, for a good operation over a certain period. It is not correct the OnePlus procedure which now deals only with the new 7T/Pro series, which works well with Android 10.
  14. O1561708387783
    O1561708387783 , via OnePlus 7 , Oct 21, 2019 :
    I have a problem after am installed this android 10 version..
    Existing apps not running this version..
    i could uninstalled the apps then installed but now also its not using...
    please help me... #onepluscommunity
  15. P1570813225656
    Eclair Oct 21, 2019
  16. E1570942910645
    E1570942910645 , Oct 21, 2019 :
    i am using one plus 7. after updating Android 10, I cant hide notch option. if you know please tell me???
  17. Georgeoneplus7pro
    You delete your data for nothing. The software is faulty.
    Ake Winther and sarahmic like this.
  18. P1570813225656
    Eclair Oct 21, 2019
    P1570813225656 , Oct 21, 2019 :
    yes same issue for me also. Fingerprint scaner is very slow. Phone also slow down. Some files open slowly. I am so disappointed.
  19. J1508070026278
    Well it works fine for me after factory reset (apart from couple of minor issues still remaining), so no regrets.
    But as I said before, us users should not have to go through the painful process of doing full wipe and factory reset for making this update work. Oneplus should have tested the update more thoroughly. Hope they come up with a more optimised update soon.
  20. amanchauhanofficial
    Donut Oct 21, 2019
