660
  1. rafael667
    Eclair Oct 21, 2019
    rafael667 , Oct 21, 2019 :
    In this version I couldn't find the Deep clear recent apps.
    Isn't it possible to change this feature now?
    It was in the advanced settings and in manage recent apps.
  2. akks
    KitKat Oct 21, 2019
    akks , Oct 21, 2019 :
    They removed it
    Georgeoneplus7pro likes this.
  3. S1538175409476
    Donut Oct 21, 2019
    S1538175409476 , Oct 21, 2019 :
    Got update to 10.0.1 and wow my battery life is horrible. Losing about 1% every 15ish minutes not touching the phone much. Hopefully it'll adjust or if it's a bug it gets fixed
    techhappy1997 likes this.
  4. Sir_Pool_de_Float_MD
    Gingerbread Oct 21, 2019
    Sir_Pool_de_Float_MD , Oct 21, 2019 :
    You will need to do some investigative work. Check your battery stats to see what app is draining so much battery power. I am running 10.0.1 on my phone, and upgraded from 10.0.0 without wipe. I have no abnormal battery drain, with over 150 apps installed.
  5. Avinash1207
    Cupcake Oct 21, 2019
    Avinash1207 , Oct 21, 2019 :
    Did anyone face issues of too aggressive backlight dimming when the phone is not in direct line with a light source. The backlight dims to the lowest brightness, making it very difficult to read. I had to manually increase brightness at times. Experiencing this after the update.
  6. Sir_Pool_de_Float_MD
    Yes. This has been an issue since the OOS 10 betas. It slowly gets better with each OTA, but still needs a lot of work.
  7. X1570117817068
  8. pzkrolik
    Eclair Oct 21, 2019
    pzkrolik , via OnePlus 7 Pro , Oct 21, 2019 :
    but why they charged me full amount of the price? Maybe I can pay half the price and after I have a great phone I'll pay the rest? If I only knew about that issues I wouldn't buy OP 7 Pro...
  9. docnok63
    Jelly Bean Oct 21, 2019
    docnok63 , Oct 21, 2019 :
    @Nic2112 @Dgafking0480 @Georgeoneplus7pro @Swejuggalo et all:
    There's been so many posts about this, I had to put it up here right away. Thanks to a post on XDA, it's now possible to get rid of the black bar below the keyboard. For non-rooted users, connect your phone and open up a command (DOS) prompt and type:
    Code:
    adb shell wm overscan 0,0,0,-100
    For rooted users, open a terminal on your phone and type:
    Code:
    su
    All credit to elmarian756 on XDA::
    https://forum.xda-developers.com/oneplus-7-pro/themes/fix-adb-disable-black-bar-10-0-1-t3987731
    If you need ADB/Fastboot on your PC:
    https://androidfilehost.com/?w=files&flid=126148
    Default value is 0,0,0,0 but I don't know why you would ever want to use it (except for this screenshot)
    Once you enter the command right instead of typing quickly you get a fixed keyboard:
    Please go on XDA and give him a thumbs up!!!
  10. S1538175409476 , via OnePlus 7 Pro , Oct 21, 2019 :
    Nothing's changed from yesterday. using the phone the same. usually it'd be in the mid 80s at this time before. unless it's the fact that OnePlus never mentioned in the changelog that "by the way all your apps will be updated" and something is happening there but I don't see anything
  11. G_Akarsh_Agrawal_ODAV
  12. Sir_Pool_de_Float_MD
    Hit the 3 dot menu and show system apps. My guess would be Google Play Services, but it could be something else.
  13. S1538175409476 , via OnePlus 7 Pro , Oct 21, 2019 :
    it's going quick. so frustrating
  14. Liviu Capitan , via OnePlus 7 Pro Nebula Blue , Oct 21, 2019 :
    well...you can try to get any new phone at half price ..see how that goes :)
    i will be patient because 7 pro is my second OnePlus phone i
    owned and i trust this brand...the comunity is great..
    maybe you should not stick to yours if some fixable issues bug you in such short time
  15. ian.philip
    Honeycomb Oct 21, 2019
    Francesco Gangi and cruzAD like this.
  16. pzkrolik
    Eclair Oct 21, 2019
    You miss the point. I didn't want cheaper device because I wanted the flawless and the best there available. Paid a lot of money and now I have to wait? I'm not a Kickstarter investor but end user and client. And I want what I paid for.
  17. cruzAD
    cruzAD , via OnePlus 7 , Oct 21, 2019 :
    Yeah, it is the same as the 10.0.0. I don't see any change. Just as buggy as the 10.0.0. Nothing became better.
    FuriousX likes this.
  18. Mikemaxe
  19. Rajat_Singh0343
    Donut Oct 21, 2019
    D1561665662980 likes this.
  20. docnok63
    @Georgeoneplus7pro et all:
    On the latest build of RiCE, OP7TPro McLaren Edition Horizon light and fingerprint animation fully functional for stable 10.0.0 and 10.0.1 users. *You'll bootloop if you try installation on OB3* You can even customize the colors on each side of McLaren animation!!!:
    It's a Magisk module, so rooted users get it here:
    https://t.me/joinchat/EsGzARBoMTcrsD2wHcqW9A
