660
  1. Rajat_Singh0343
    Donut Oct 22, 2019
    Rajat_Singh0343 , via OnePlus 7 , Oct 22, 2019 :
    I am also facing similar issue. I can't even play music via it but able to take calls.
  2. nitin32
    Cupcake Oct 22, 2019
    nitin32 , via OnePlus 7 Pro , Oct 22, 2019 :
    There is still problem with ui, gestures and function
    Sometimes device hang for couple of seconds in camera, third party apps etc.
    Home gesture in recent menu stops working which is annoying.. And first need to use back gesture and we can go to home screen.
    Please fix this.
    And Micro mode is missing.
  3. JNiemi
    Gingerbread Oct 22, 2019
    JNiemi , via OnePlus 7 Pro Nebula Blue , Oct 22, 2019 :
    It has been fixed. Try version 9.5.xxGM21AA.
    That version has been proved to be:
    - Stable
    - Not draining battery as fast
    - Bluetooth working properly
    - WiFi working properly (2.4 GHz and 5 GHz)
    - Warp Charge will work
    - Not have surpricing reboots
    plus all sorts minor fixes.
    Krampimp likes this.
  4. JaberN.Habash
    Donut Oct 22, 2019
    JaberN.Habash , via OnePlus 7 Pro , Oct 22, 2019 :
    how i can back to pie ?
  5. YauhenK
    Donut Oct 22, 2019
  6. E1517844213356
    E1517844213356 , Oct 22, 2019 :
    after starting camera app, mobile hangs and then restart
    this problem prevails even if using camera through other apps
  7. Senthil_Jarvis
    Eclair Oct 22, 2019
    Senthil_Jarvis , Oct 22, 2019 :
    Why there is a grey line appearing at the end of the screen after the update? What is that for? Spoils the Home screen. Please guide or help.
  8. Q1547544122748
  9. P1566572919841
    P1566572919841 , Oct 22, 2019 :
    After new update OS 10, unable to open resent apps in background swipe up is not working until we restart the device and also battery is bit draining. please fix these bugs thank you.
  10. Alexey Zaytsev
    Eclair Oct 22, 2019
    Alexey Zaytsev , Oct 22, 2019 :
    Brief review of update 10.0.1 The battery holds excellent !!! The scanner is fast. Everything works well and smoothly. Of the minuses, the fingerprint animation disappears belatedly, the auto brightness does not work correctly, the brackets from the bottom in the corners of the screen when unlocking, calling the assistant in new gestures. I also don't like the new multitasking animation. The rest is no problem. The phone is working fine
  11. AdityaAgrawal516 , via OnePlus 7 Mirror Gray , Oct 22, 2019 :
    why regularly I am facing this nonsense downloads in my file app, please look power in removing this bug in the next update. This is taking my storage and drivinh me crazy. currently on oneplus 7 running 10.0.1
    mayur.rm.01@gmai and Krampimp like this.
  12. Ajikdevadas
    Froyo Oct 22, 2019
    Ajikdevadas , Oct 22, 2019 :
    i have experienced certain bugs...i have given feedback
    1.unresponsive touch in bottom screen
    2.freezing of certain 3rd party apps
  13. udeshvirk
    Honeycomb Oct 22, 2019
    udeshvirk , via OnePlus 7 , Oct 22, 2019 :
    Anybody from India with JioFiber and using JioCall app for fixedvoice calling. App is not connecting to JioFiber after Android 10 update. It is working fine on my other mobiles.
  14. J1571643704732
    J1571643704732 , via OnePlus 7 Pro , Oct 22, 2019 :
    rahulgogia5
    After upgrading to Android 10, I have 2 Google pay installed in my phone. Can someone please explain why there 2 G pay and what's the functionality of 2nd one?
  15. J1571643704732
    plz just disable the app. bcz one g-pay is inbuilt app in new android 10 so u can just disable the app. otherwise u can uninstall the 2nd one nd use inbuilt also.
  16. O1560865615525
    O1560865615525 , Oct 22, 2019 :
    Thank you for the fast update. Other brands are way behind. I'm very happy with the new features.
    Greetings from the Netherlands!
