648
  1. JAK246
    Cupcake Oct 22, 2019
    JAK246 , Oct 22, 2019 :
    After updating android 10.0.1 version, video call options is not working in my phone.
  2. K1570692621709
  3. J1508070026278
    Gingerbread Oct 22, 2019
    J1508070026278 , via OnePlus 7 , Oct 22, 2019 :
    In my case it fixed 99% of the issues.
    however keep in mind that i did Not restore from a backup and had only synced my contacts and pictures to google.
    had to go through the painful process of manually installing all my app after the factory reset.
    Tedinetto likes this.
  4. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 22, 2019 :
    I'm on beta 3...I factory reset at beta 1 and did not use any type of backed up material and I chose to manually install everything rather than letting Google do it for me during the setup process. Have since then OTA up to beta 3. I just finished a 10 day period of time without any reboots of any kind. No crashing apps, temporary frozen gui or any strange behavior.
    While several get boot loops and random reboots on beta 3 I only got minor flaws since first beta that I report and got fixed in later releases.
    Some possible things that may be the reason
    1. All my installed apps a perfect and made for Android 10 (no... Atleast one have graphical flaws and several has no official 10 support)
    2. My phone is a golden sample and has recived a blessing from God and Pete Lau has personally assembled the phone. (I'm an ateist so I'd don't give a **** about blessings [e]1f609[/e] Nor don't I think Pete has magic fingers)
    3. My hatred towards backups and fondness of factory reset after a major version upgrade has paid of. (most probable I would say)
    It's not a new thing that a clean start has some benefits. It does not solve everything though.
    Please use the feedback tool to report this issue. It exist within the community app.
    If they need more info they will contact you via PM.
  5. Ashish Meher 7676
  6. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 22, 2019 :
    Some. But not all. Depends on the issue.
    It also seems to matter on what kind of backups you do. The lesser the better. If you want to maximize your chances of getting rid of some bugs don't do full app data backup and every single system setting. Backup what matters (in my world that would be media files. I always use online storage like Onedrive/Dropbox for important filesnso I don't even need such a backup).
  7. DrBrahmesh likes this.
  8. lobinho68
    lobinho68 , Oct 22, 2019 :
    Estou np OP beta 3.
    O meu OP é 1910
    Vou receber via OTA oficial 10.0.1?
    Obrigado
  9. Tedinetto , via OnePlus 7 Pro Mirror Gray , Oct 22, 2019 :
    And if I just tolerate and wait for the next update? Do you think OnePlus will fix all these bugs? I really don't want to do a factory reset... [e]1f612[/e]
    L1570605140306 likes this.
  10. stasonn777
    stasonn777 , Oct 22, 2019 :
    Using OxygenOS 10.0.1 on Op7 and noticed that batary began to hold a charge badly. Any body have the same problem?
  11. Marcstang04
    jasprjay likes this.
  12. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 22, 2019 :
    Yes some stuff will probably improve without factory reset eventually. Either by a system update or app update. In separate app cases you can wipe the app data of only that app. Or even reinstall some apps to see if it matters and fix some issues. And report the issues to Oneplus of course.
  13. Tedinetto , via OnePlus 7 Pro Mirror Gray , Oct 22, 2019 :
    Thanks!
  14. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 22, 2019 :
    Macro mode relies on minor hardware changes. I haven't seen physical proof of the internal changes in 7 Pro vs 7T Pro yet though. But there have been talk about some motor in the camera module.
    I'm not into the details of 7T series but do they really offer real super stable in 4k? Real 4k super stable would mean recording beyond 4k and cropping it down to 4k with a combined OIS and EIS technology.
    G_bhargava_reddy_AFDZ likes this.
  15. X1559993440643
    smitmakani likes this.
  16. akks
    Jelly Bean Oct 22, 2019
    akks , Oct 22, 2019 :
    Macro mode won't be available for 7 pro, as confirmed by OnePlus staff, here:
  17. akks
    There are n number of methods of you search on Google
  18. chetannd
    Eclair Oct 22, 2019
    chetannd , Oct 22, 2019 :
    Just install google contact and let it sync ...I think this will help.
