660
  1. scrin378 , via OnePlus 7 Pro Nebula Blue , Oct 22, 2019 :
    Emoisemo
    So strange..
    So many people in this forum there is bugs inside os 10.
    Battery drain, laggy, non responsive apps and so.. And so..
    As my experience, os10 works perfect and almost no issue at all..
    Thank God maybe im lucky..
    Im on OP7 pro 12 gb / 256 Gm1913
    Who:s with me??​
    Yes.. same here and same configuration. No problems so far, battery is much better then pie, i get near 7h sot. Dont know why people get so much errors and bugs!
    Everything is working smooth like a butter
    God job OP Team
    Emoisemo and J1508070026278 like this.
  2. Tedinetto
    Gingerbread Oct 22, 2019
    Tedinetto , via OnePlus 7 Pro Mirror Gray , Oct 22, 2019 :
    without factory reset?
  3. Emoisemo
    Froyo Oct 22, 2019
    Emoisemo , via OnePlus 7 Pro , Oct 22, 2019 :
    I guess we are the lucky one??
  4. Emoisemo
    Froyo Oct 22, 2019
    Tromulu7 and J1508070026278 like this.
  5. TommyHammy
    TommyHammy , Oct 22, 2019 :
    Same here. It seems to be just Indian people who are having problems.
    Johan Notte and Emoisemo like this.
  6. Emoisemo
    Froyo Oct 22, 2019
    Or maybe some people that playing around with unofficial os updates.. And they got bugs from it, then before they do updates and after never do any factory reset and clear cache
    J1508070026278 likes this.
  7. JNiemi
    JNiemi , Oct 22, 2019 :
    !! Bang on :D !!
  8. docnok63
    Jelly Bean Oct 22, 2019
    docnok63 , Oct 22, 2019 :
    The only difference is the aperture of the telephoto lens:
    https://www.dxomark.com/oneplus-7-pro-camera-review/
    https://www.gsmarena.com/oneplus_7t_pro-review-2008.php
    I really wish I could speed up my work, but I've had to teach myself how to tear apart, rebuild, and sign apks this week. It was a heck of a learning curve. This was my first build trying to put OB1 features in v3.8.71 apk:
    These first two apks wouldn't even install, but I've gotten that sorted now. As I said, I've rebased off of v3.8.72 now but I've run into easy install for all (via sideloading apk) with some loss in functionality vs full functionality but requiring root (to delete and then reinstall directories/apks.) I'm trying to get it all with limited/no success.
    If you're talking about the Oxygen Updater app and/or XDA links, those files come straight from OP servers. There's no such thing as an "unofficial os update" and you should never clear cache: http://bit.ly/2J1KroY
    JNiemi likes this.
  9. H1563329292689
    Cupcake Oct 22, 2019
  10. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 22, 2019 :
    Very good here too (on beta 3)
    JNiemi and Emoisemo like this.
  11. Cipixxx
    Eclair Oct 22, 2019
    Cipixxx , via OnePlus 7 Pro , Oct 22, 2019 :
    I'm still on Oxygen 10 build OP7Pro2_beta3 wich I downloaded and installed from OnePlus support website. will I get the 10.0.1 OTA update ?
    I tried downloading the "latest final" 10.0.1.GM21BA version from OnePlus website but upon installation it says my build is newer and downgrade is not possible.
  12. iAshok99
  13. JNiemi
    Im using on OnePlus 7 Pro 10.0.1 (test phone) with OnePlus camera app 3.8.13 and that includes SuperMacro, and camera is working just fine.
    Have explored how to enable that macro feature on this never camera apps, cant say it has been succes yet.
    @docnok63 have you noticed that camera app is calling home, why so?
    Georgeoneplus7pro likes this.
  14. Kieran_C
    Kieran_C , Oct 22, 2019 :
    Just an update, I also think something has happened to cellular connection. When I am at places that I usually get 4G signal I now dont get any network connection. Also when I am at a place that I do have 4G the symbol doesn't show next to the signal strength symbol
  15. JmcRepair33
    Ice Cream Sandwich Oct 22, 2019
    JmcRepair33 , Oct 22, 2019 :
    LOL :p
  16. VishalSah22
    VishalSah22 , Oct 22, 2019 :
    Hey can you please help me with the working links of Google camera mod for my OnePlus 7. I really wanna try it out once.
  17. JmcRepair33
    Did you reset the Network in reset and backup in settings, Dont reset the phone just network connection. Also try to reset your apm which really wouldnt matter if you dont have signal but worth a try after resetting reset the apn to default in mobile networks
  18. T1571417251617
    T1571417251617 , Oct 22, 2019 :
    The apk cam is already at version 3.8.72 and mine is still at 3.8.69. When will OnePlus people be updated?
    My model is 7 Pro, and I'm running Android 10 on the latest version of OP.
  19. B k
  20. Cipixxx likes this.
