660
  1. Aomar79
    Eclair Oct 23, 2019
    Aomar79 , via OnePlus 7 Pro , Oct 23, 2019 :
    Had it on pie, go to apps, search for Android setup, force stop and clear cache. worked for me. Hopefully works for you.
  2. kapilbhaskar23
    Eclair Oct 23, 2019
    kapilbhaskar23 , Oct 23, 2019 :
    battery drain issue..what is SOT in your phone?
    E1568024918182 likes this.
  3. rafael667
    Eclair Oct 23, 2019
    rafael667 , Oct 23, 2019 :
    In the settings there's a alert of the internet. If I have wifi and mobile data off is displayed an alert in the android settings.
    Is there a way to disable that?
  4. Xxsobe01xx
    Eclair Oct 23, 2019
    Xxsobe01xx , Oct 23, 2019 :
    I have the one plus 7 pro and I've been waiting for this Android 10 update . when will it be available for the rest of us ???
  5. akks
    KitKat Oct 23, 2019
    akks , Oct 23, 2019 :
    It's already available in OnePlus download section
  6. Xxsobe01xx
    Eclair Oct 23, 2019
    so it's not under system update ??
  7. Xxsobe01xx
    Eclair Oct 23, 2019
    where is the one plus download section at ??
  8. Xxsobe01xx
    Eclair Oct 23, 2019
  9. Nic2112
    Ice Cream Sandwich Oct 23, 2019
  10. cerberuslegend
    Cupcake Oct 23, 2019
  11. Shoubhik23
    Shoubhik23 , Oct 23, 2019 :
    Post update facing lots of issues with many apps.
    During whatsapp video call, user cannot go back in whatsapp and use it since it hangs n unresponsive.
    Anybody facing similar issues?
  12. Shoubhik23
    Yes facing the same issues
  13. I1559277304865
  14. Veera Geeky
    Donut Oct 23, 2019
    Veera Geeky , via OnePlus 7 , Oct 23, 2019 :
    in my one plus 7 iam installd open beta 3 .
    now iam downlod the 10.0.1 from the forum and trying to install
    I showng software downgrade is not available because of bootup failiure .
    what can I do?
    some one please help me into this
  15. Nic2112
  16. Nic2112
  17. Emoisemo
    Froyo Oct 23, 2019
    Emoisemo , via OnePlus 7 Pro , Oct 23, 2019 :
    Yang anak Indo mana suaranya??
    Gw berhasil nih update ke os 10.01 dan semua baik2 aja..
    Gak kyk yg pada complain di forum..
    Malah ini menurut gw lebih oke dr os sebelumnya..
    Yg sama kyk gw ayo ngacungg.... [e]263a[/e][e]263a[/e][e]263a[/e][e]263a[/e]
  18. Emoisemo
    Froyo Oct 23, 2019
  19. Sajidur Rahman
    Eclair Oct 23, 2019
  20. Emoisemo
    Froyo Oct 23, 2019
    You go to setting then to the system. It will automatic ask you to download
