660
  1. ShoRahman
    Eclair Oct 23, 2019
  2. AdityaAgrawal516
    Gingerbread Oct 23, 2019
    W1571547904827 likes this.
  3. Atiq1989
    Froyo Oct 23, 2019
  4. W1571547904827
    Cupcake Oct 23, 2019
    W1571547904827 , Oct 23, 2019 :
    yes.. I'm also facing the same problem. also hiding notch is not available. sometimes chrome hangs
    AdityaAgrawal516 likes this.
  5. docnok63
    Jelly Bean Oct 23, 2019
    docnok63 , Oct 23, 2019 :
    1) Check the app's permissions that they have notification permission
    2) Go to settings\battery\battery optimization and set permission of apps you're missing notifications from to "Don't optimize"
    Try: https://play.google.com/store/apps/details?id=com.xda.nachonotch&hl=en_US
    1) Force stop Play Store and clear app data...doesn't work...
    2) Force stop Play Store and Google Play Store clear storage for both. Doesn't work?
    3) Force stop Play Store and Google Play Store clear storage and log out of your Google Account on the phone. Shut down phone. Log on to your Google Account on PC. Now log out and then log right back in. Power on phone and log back in to Play Store.
    Mete2 and Georgeoneplus7pro like this.
  6. Amits7251
    Froyo Oct 23, 2019
    Amits7251 , via OnePlus 7 , Oct 23, 2019 :
    battery backup has reduced now dash charge works only upto 72% after that it takes more than a hour around 70 minutes to charge from 70% to 100% idk why they reduced battery performance
    earlier it took 75 minutes from 0to 100 now it takes 1hour and 40+ minutes to charge from 0 to100
  7. AdityaAgrawal516
    AdityaAgrawal516 , via OnePlus 7 , Oct 23, 2019 :
    you are providing me another way around to install a stupid app to get my notch hidden which would be running in the ram. I am questioning oneplus on its stupid choice of removing hide notch! We all customers want it! Every customer running android 10 on Oneplus device! 7, 7 Pro, 7T, 7T Pro!!!!!
  8. Amits7251
    Froyo Oct 23, 2019
    yes it has become like normal charging of budget phones and. dash works upto only 72 after that more than a hour to reach 100 from 70
  9. Amits7251
    Froyo Oct 23, 2019
    yes same here
  10. W1571547904827
    exactly.. we want notch hide option in settings as it used to. also battery backup is not good.
  11. W1540933440984
    W1540933440984 , via OnePlus 7 , Oct 23, 2019 :
    Bonjour après mise à jour il y a 8 jours, je ne peux plus utiliser paylib sans contact de la bnp. le message d'erreur est le suivant :
    L'utilisation du paiement mobile sans
    contact nécessite une version officielle
    de système d'exploitation Android.
  12. F1562673465005
  13. docnok63
    Pro users don't have a notch so....
    Veuillez utiliser l'anglais dans ce forum, sauf si le fil de discussion commence par [FRENCH] dans le titre du fil de discussion.
    I don't know what contact bnp is. I think your banking app needs an update to Android 10 in order to work
    Georgeoneplus7pro likes this.
  14. IDeb@21
    IDeb@21 , via OnePlus 7 Pro , Oct 23, 2019 :
    The nature at it's beast in Bengaluru!!!!! While the clouds [e]2601[/e]️ explaining the situation of happiness, the rain is coming to get the dance of the nature! The tree here signifies the green environment. And the beautiful construction of the building signifies the art work!!!!! [e]1f334[/e]
    Clicked on my One Plus 7 Pro
    Edited on Snapseed
  15. AdityaAgrawal516
  16. Marvido
    Donut Oct 23, 2019
    Marvido , Oct 23, 2019 :
    What a crap upgrade, my batteri is draining faster than ever. In less than 3 hours it has drained 30% battery by just lying without use. I have never before had that issue....
  17. O1561288468673
    Donut Oct 23, 2019
  18. O1558658063755
    O1558658063755 , Oct 23, 2019 :
    I can't publish a long story on Instagram .Only the first video is getting published. it's been 8 hours that the others are "uploading" . I can't even switch my account
    WhatsApp is crashing again and again
    and I can't access to the médias previously shared with someone
    GPS signal is not accurate
    All my pictures categories were empty this morning
    my battery is getting lower sooner even if I am under economy of energy !
    I really need support
    regards
    ZalımBabo likes this.
  19. Georgeoneplus7pro
    Georgeoneplus7pro , Oct 23, 2019 :
    Report these issues!
  20. sirfuzzhead
    Eclair Oct 23, 2019
