660
  1. J1508070026278
    Gingerbread Oct 23, 2019
  2. T1559146324970
    Cupcake Oct 23, 2019
    T1559146324970 , Oct 23, 2019 :
    bonjour depuis la dernière maj de 113mo . mon téléphone déconne . il bloque sur des apps .. a du mal a s'allumer ..
    si vous avez une solution merci
  3. Azhar Syed likes this.
  4. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 23, 2019 :
    What version do you have? T-mobile?
  5. Azhar Syed
    Froyo Oct 23, 2019
  6. K.Rambabu
    Donut Oct 23, 2019
    K.Rambabu , Oct 23, 2019 :
    Hi One plus Team,
    after Android 10 upgradation some times system hang and lags are observed so please rectify this problem with next security patch.
  7. Q1571786366193
    Q1571786366193 , Oct 23, 2019 :
    same problem
  8. Djovanni77
    Eclair Oct 23, 2019
  9. G1558842425747
    Eclair Oct 23, 2019
    G1558842425747 , Oct 23, 2019 :
    My phone hasn't had any of the problems people mention here except the following:
    1. Fingerprint sensor has actually slowed down. it's not too bad but on Pie it was better.
    2. The white bar at the bottom of the screen is a bit weird and I personally don't like it.
    This is what I have encountered so far. Been a good experience for me so far.
    Rick_980B likes this.
  10. Arnaud_Ieè
    Eclair Oct 23, 2019
  11. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 23, 2019 :
    If you really want it fast you can go to Oneplus homepage and download it.
    Support/Software Upgrade
    Then you can do a local upgrade. The file needs to be named .zip and exist in local storage to be found by the local upgrade
  12. weileyi
  13. thanoskalk
    J1508070026278 likes this.
  14. N1542054536873
    N1542054536873 , Oct 23, 2019 :
    installed it via oxygen updater but it.s not that smooth
    oneplus weather app crashing when trying to enter settings
    didn.t this update include wide video support?
  15. JNiemi
    JNiemi , Oct 23, 2019 :
    Ive reported same thing early on DP1, but seems like it is so minor problem that OP doesnt give a shit.
    Georgeoneplus7pro likes this.
  16. M1570686462126
    M1570686462126 , Oct 23, 2019 :
    Notifications are not working properly specially hike notifications after updating OxygenOS 10.0.1 in one plus 7
  17. Georgeoneplus7pro
    Jelly Bean Oct 23, 2019
    Georgeoneplus7pro , Oct 23, 2019 :
    Wide video support moved to the 7T series after being tested with Beta on the 7 series.
  18. jigardevmurari
    Donut Oct 23, 2019
    jasprjay and J1508070026278 like this.
  19. M1570686462126
