660
  1. Anish1510
    Cupcake Oct 24, 2019
    Anish1510 , Oct 24, 2019 :
    hello,
    I updated my OnePlus 7 pro with the new update and since then have been facing problem with WhatsApp calling through my network. Everything works fine when I'm on a WiFi but just when I use my network for WhatsApp calling it doesn't connect. Initially I thought it was the carrier issue but then I realized that this error arrived only after the new update. Still unsure what's the exact issue but I think it's the new version of update. please help me out in this scenario.
    thank you
  2. Headcleaner67 , via OnePlus 7 Pro Nebula Blue , Oct 24, 2019 :
    same here. the screenshot is/was a dark theme
    Z1558843799122 likes this.
  3. Georgeoneplus7pro
    Jelly Bean Oct 24, 2019
    Georgeoneplus7pro , Oct 24, 2019 :
    :DAfter any OxygenOs update you need to return to the factory settings because it will not work otherwise. And if it is possible, for the optimum operation, do not install any application. Conclusion drawn from many posts to forums of OxygenOS update.
    JNiemi likes this.
  4. dantusris
    Gingerbread Oct 24, 2019
    dantusris , via OnePlus 7 Pro , Oct 24, 2019 :
    My phone didn't flag the availability of this update since the past 12 days in the US nevertheless, downloaded and updated it from the OnePlus site.
    After the update, all the functions work normal (Bluetooth Auto connecting to vehicles, WiFi, voice, apps, swipes, battery consumption, etc) except for two issues:
    1. The Bluetooth output to bullets is low and the speaker output seems to be lower.
    2. Weather app doesn't work.
    These need a fix.
    Happy with the update otherwise reading all things could go wrong.
  5. sarahmic
    Honeycomb Oct 24, 2019
    sarahmic , Oct 24, 2019 :
    Hi Asm
    Is battery better please?
  6. Tyronnster
    Ice Cream Sandwich Oct 24, 2019
    Tyronnster , via OnePlus 7 Pro , Oct 24, 2019 :
    I find playing games laggy.
    when I am playing FIFA mobile it is fine then when I click away to do something I.e reply to text then go back to the game it lags like mad
  7. Asm Abdullah , via OnePlus 7 Pro Nebula Blue , Oct 24, 2019 :
    Bettery issue is solved
    raise phone to ring down added
    what's app calling problem solved
    keyboard below space minimized
    finger print scan speed back to normal
    low light flickering is solved
    charging heat issue plus heating during game play solved
    charging time is slightly increase although in thise update it takes almost 120+ minutes to 0-100. previously on pie it was 115mins ..
    that's all as far as i know
    sarahmic likes this.
  8. Venkatraghu2001
  9. L1571941773874
    L1571941773874 , Oct 24, 2019 :
    one plus team i am greatly disappointed with the new update os 10 , my phone is getting slower and slower, everyday there is new problem and my phone is not even one month old. Power on off button working slowly, camera is slow, device mute itself on its own, phone lags while using dark mode, call features also lags. could you please consider that we are spending a huge amount to get our devices.
  10. Kieran_C
    Kieran_C , Oct 24, 2019 :
    Another update on this. The visuals have appear to be fixed now when dismissing notifications. My network issues also seem to be fixed after resetting the settings and rebooting my phone numerous times. The app switcher is still horrendously laggy however.
    Glad to see things are getting fixed though!
  11. HCHarshChheda
    Q1570482221685 likes this.
  12. Georgeoneplus7pro
    You give us hopeful my friend, in these times when many we doubt our phones, that they will ever work properly.
    sarahmic, docnok63, Faden_art and 2 others like this.
  13. A1571419460220
    Froyo Oct 24, 2019
  14. Faden_art
    Eclair Oct 24, 2019
  15. Faden_art
    Eclair Oct 24, 2019
    Faden_art , via OnePlus 7 Pro , Oct 24, 2019 :
    That's not exactly true. They still care but can't hear everyone.
    The problem is they tried to be the fastest for Android 10 and now we're the ones that get the rushed updates. I would have loved if they tested it 1 month more and then released it with less bugs.
    Android 10 should be an upgrade and not a downgrade because of missing features and bugs....
    Dirk66 and Georgeoneplus7pro like this.
  16. G_Divyansh_Jain_96
    G_Divyansh_Jain_96 , Oct 24, 2019 :
    This one is also not working good this is not keeping any apps on the memory every app will reload or I have to close the app and to restart for every use
    and there are glitches in using I am previously using 3t but this one is lagging more and it's visible sometimes camera doesn't focus sometimes this thing just slow down is anyone having same issue ?
    my handset is just 3 days old and I am also not able to replace it
  17. Georgeoneplus7pro
    No one asked for OnePlus to bring us Android 10 before the others. It is not convenient to reset our phones and lose our data with endless testing. We prefer a delayed update, but stable and performance, as Samsung correctly does. Really please OnePlus team not to hurry up and give us bad updates.
  18. Attached Files:
    Georgeoneplus7pro likes this.
