660
  1. akks
    KitKat Oct 25, 2019
    akks , Oct 25, 2019 :
    Oos 10 being a major update and many random bugs reported by many, factory reset solves most of them. I repeat, I'm yet to encounter any bug and not yet reset;)
    A1560648267550 and wospino like this.
  2. v.soni
    Cupcake Oct 25, 2019
    v.soni , via OnePlus 7 Pro , Oct 25, 2019 :
    I would like to suggest more customization for Horizon lights. for example, it could be compatible with music or changing animation or color wheel for notification .
    RAHUL941 likes this.
  3. v.soni
    after a call on instagram the volume buttons are always set to call mode and can't be switched to music or other options. the only way is to reset the device and then the volume buttons are back to music. But the problem still happens. Please fix. very annoying
  4. wospino
    Ice Cream Sandwich Oct 25, 2019
    wospino , via OnePlus 7 Pro , Oct 25, 2019 :
    same here, I'm have no bugs for now...
    A1560648267550 likes this.
  5. beta3d10
  6. akks
    KitKat Oct 25, 2019
    I guess most of the bugs are for OnePlus 7.
    My 7 pro, it's rock stable. Not even hard reset done yet.
    Emoisemo and HZ_ND like this.
  7. akks
    KitKat Oct 25, 2019
    Use the feedback tool in the app, if you really want OnePlus to hear your suggestion
    Faden_art likes this.
  8. HZ_ND
    Gingerbread Oct 25, 2019
    HZ_ND , via OnePlus 7 Pro , Oct 25, 2019 :
    akks
    Use the feedback tool in the app, if you really want OnePlus to hear your suggestion​
    They won't listen and they will keep on posting stuff here which is not helpful at all.
  9. uk_ramprasad
  10. G_VINAYAK_PATIL_tfcX
    Eclair Oct 25, 2019
    G_VINAYAK_PATIL_tfcX , Oct 25, 2019 :
    Hi, while playing pubg after update to android 10 on my OnePlus 7, it is not playing completely in full screen. all controls which are not movable and options like maps are moved inside from edge. does anyone facing same issue?
  11. Abhik.b02
    Froyo Oct 25, 2019
    Abhik.b02 , Oct 25, 2019 :
    Isn't Android 10 supposed to bring music seek controls baked right into notification tray as well? I don't see that in my lockscreen as well.
    I don't see this here.. I am using JioSaavan app for streaming.
  12. SenTamizhan
    Eclair Oct 25, 2019
    SenTamizhan , Oct 25, 2019 :
    I am currently running on 9, everybody telling issues after installing 10, so I would like to stay for the next incremental update. I have a doubt, should must install this firmware for next incremental or not.
    P1570813225656 likes this.
  13. docnok63
    Jelly Bean Oct 25, 2019
    docnok63 , Oct 25, 2019 :
    I don't do SoT tests very often, but this is bad for forced 90 Hz @QHD. Using Kiri kernel and RiCE to maintain battery. Glad to see Google Play Services drain is gone.
    Georgeoneplus7pro likes this.
  14. govindakatkamwar
    govindakatkamwar , Oct 25, 2019 :
    installed update but here goes first issue from my usage
    Bug Report
    *When connected with Bluetooth headset most of the time call automatically goes to phone and Bluetooth headset even if connected doesn't work.
    *Autobrightness is not working most of the time.
  15. alaminnshaikh
    Eclair Oct 25, 2019
  16. pzkrolik
    Eclair Oct 25, 2019
  17. Emoisemo
    Froyo Oct 25, 2019
    Emoisemo , via OnePlus 7 Pro , Oct 25, 2019 :
    Yes sir...
    My op7 pro also rocks!! No issue at all
    akks likes this.
  18. akks
    KitKat Oct 25, 2019
    Factory reset isn't mandatory. Do it only if you come across any major software issue which can't be handled by basic troubleshooting methods
