660
  1. D1566875042308
    Cupcake Oct 30, 2019
  2. N.VamsiKrishna
    Froyo Oct 30, 2019
    N.VamsiKrishna , via OnePlus 7 , Oct 30, 2019 :
    Settings > Customisation> Present theme > First ,Select vibrant tints and apply then again select naunched dark theme and apply .
    Restart ur mob (optional , if its fine no need ) .
    It worked for me.
    L1569486940430 likes this.
  3. SigmaTheDJ
    SigmaTheDJ , Oct 30, 2019 :
    I'm experiencing a very annoying bug since the update to 10.0.1. Maybe 20% of the time when the phone has been sitting idle and I tap the screen to wake the ambient display, rather than turn off after 3 seconds, it's stuck on. When this happens I have to unlock the phone, then tap the power button and the display will then turn off.
    I've done a full factory reset of the phone twice, but it has made no difference.
    Is there any way I can downgrade back to the previous version of the OS?
  4. N.VamsiKrishna
    Froyo Oct 30, 2019
    Yes , u can downgrade to pie but it will wipe all your data.
  5. anilwithu
    anilwithu , Oct 30, 2019 :
    I feel it's buggy .. some times phone behaves different .. op3 was better and it was stable. app permissions and in home screen shelf tool box was working all of sudden not working from today. I was using op3 from 3.4 yrs on that impression bought op7. But it's not worth the money compare to op3. And in a month reduced 3 k price as well ..
  6. L1569486940430
    Donut Oct 30, 2019
    L1569486940430 , Oct 30, 2019 :
    Thank you
  7. G_BBall_KLHS
    Eclair Oct 30, 2019
  8. dsiz_prince
    Froyo Oct 30, 2019
  9. N.VamsiKrishna
    Froyo Oct 30, 2019
    dsiz_prince
    my current build number ends with 57BA
    OnePlus site has a build 57AA
    how do i know which one is the latest​
    Try to change country option in OnePlus Official site , Choose your country for correct build .
    57AA is an India build number.
  10. jatin0990
    Gingerbread Oct 30, 2019
  11. Korok Hidup
    Korok Hidup , via OnePlus 7 , Oct 30, 2019 :
    global
  12. dsiz_prince
    Froyo Oct 30, 2019
    dsiz_prince , Oct 30, 2019 :
    If I navigate to the update page from US , I dont see Oneplus7 Listed, I brought this device from India and now I am looking for device updates
  13. N.VamsiKrishna
    Froyo Oct 30, 2019
  14. dsiz_prince
    Froyo Oct 30, 2019
  15. Korok Hidup
    dsiz_prince likes this.
  16. Mohd_Sameer_
    Eclair Oct 30, 2019
    Mohd_Sameer_ , Oct 30, 2019 :
    There are still some bugs like battery is draining a bit faster and some performance optimization.
    G_Nihar_Jain_ likes this.
  17. Mohd_Sameer_
    Eclair Oct 30, 2019
  18. Atiq1989
    Atiq1989 , via OnePlus 7 Pro , Oct 30, 2019 :
    After updating Android 10 i Can't find "Recent App management" (Normal Clear or Deep Clear) option in system setting.
    can you please tell me where it is or removed.....?
    we strongly want this feature.......
  19. dtrs
    dtrs , via OnePlus 7 , Oct 30, 2019 :
    OnePlus 7 128/6
    Updated to 10.0.1 about two weeks ago:
    Good stuff:
    - overall performance feels better than latest 9.x.x
    - fingerprint sensor works faster
    - battery life improved, but a little (about 6-7,5 SOT/day, usually go to sleep with 17/20%). Maps/navigation, music in the car and during the work day, some social network apps, messengers, YouTube. No gaming.
    Issues:
    - auto brightness works awful. Most of the time looks like it doesn't work at all. But sometimes it works not relevant to surrounding conditions - maximize brightness in dark, or minimize in-room, with bright lights, to the minimum level ( almost blacked-out screen).
    - strange empty space below the keyboard, which can minimize keyboard when you accidentally touch it. Annoying, because it is easy to touch it when typing with spaces. In Chrome touching this space closes the keyboard and switches focus from search field. Gesture button switched off, using only gestures.
    - sometimes proximity sensor fails, and screen switches on during the call, touchscreen also works (all that annoying stuff with 'oh, wait, loudspeaker is on', or 'sorry, my face decided to end call'). Remembered me my old OnePlus One :)
    - no 'Smart Display' option in settings
    At all - happy with the update.
    B1570649888267 likes this.
  20. C1572459888649
    C1572459888649 , Oct 30, 2019 :
    I have one plus 7 purchased ,it's been less than a month,after upgrading to Android 10 ,wen I make a call all of a sudden dead silence then phone works,it's been difficult to disconnect call it takes 10sec for call disconnecting,and when I'm trying to send any file or picture in WhatsApp it keeps rotating it doesn't get loaded up,I HV been facing all of these problem after updating the version
