659
  1. Pavana__D
    Eclair Oct 12, 2019
    Pavana__D , Oct 12, 2019 :
    did you use vpn
  2. _Sumit_Sati_
    Cupcake Oct 12, 2019
    surajgupta07 likes this.
  3. ShubhamDalal
  4. shahnisarg
    Froyo Oct 12, 2019
    shahnisarg , Oct 12, 2019 :
    No option of smart display is there to check in display/ambient display/ in 10.0.1 update
  5. U1558552994291
    Eclair Oct 12, 2019
  6. I1565596575283
    I1565596575283 , Oct 12, 2019 :
    umm...No
    Regular wifi network
    received the update on my phone
  7. _Sumit_Sati_
  8. I1565596575283
    GM1901 model
    _Sumit_Sati_ likes this.
  9. Swejuggalo
    KitKat Oct 12, 2019
    Swejuggalo , Oct 12, 2019 :
    Nuanced dark + force dark mode? Probably that is why then.
    If you use stuff in developers options expect problems. It's called "developer" for reasons
  10. ShubhamDalal
  11. Pavana__D
    Eclair Oct 12, 2019
  12. Pavana__D
    Eclair Oct 12, 2019
    can you send the system info screenshot
  13. Pavana__D
    Eclair Oct 12, 2019
  14. Swejuggalo
    KitKat Oct 12, 2019
    You were on 9 before? Is yes probably your bank that needs to update their apps.
  15. Yash Narain
    Gingerbread Oct 12, 2019
    Yash Narain , via OnePlus 7 Mirror Blue , Oct 12, 2019 :
    I've found that dude...you have to go to the developer options and disable override dark theme. then you will get the white colour notification shade. But the problem is that whenever you change the theme and come back to the dark theme , it again becomes black and you have to go to developer options again to disable that option.
  16. Komalpreet_Sandhu
