658
  1. Z1571762152566
    Donut Nov 10, 2019
    Z1571762152566 , Nov 10, 2019 :
    everything runs perfectly!!! remember to do a factory reset and wipe cache and delvik!!
  2. Karan7920
    Cupcake Nov 10, 2019
    Karan7920 , Nov 10, 2019 :
    Facing network issue after update to android 10 in one plus 7. Internet stops working for a while and my voice is not received to other caller sometimes also. Please provide the suggestions!
  3. R1568953270199
    R1568953270199 , Nov 10, 2019 :
    help help!!! after updating android 10 in one plus 7, apps are crashing.Play store not working,cannot update or download apps. maximum apps showing error or crash in opening. suggest what to do.
  4. POE65
    Eclair Nov 10, 2019
    POE65 , via OnePlus 7 , Nov 10, 2019 :
    You can try clear cash OR a factory reset.. OR downgrade tot Pie...
  5. IVANJOHNSON
    Eclair Nov 10, 2019
  6. sechinov
    Ice Cream Sandwich Nov 10, 2019
  7. Mr._Stark
    Donut Nov 10, 2019
  8. Z1571762152566 likes this.
  9. Areebanwar
    Honeycomb Nov 10, 2019
    Areebanwar , Nov 10, 2019 :
    I've a question -
    Is the camera preview/quality supposed to be directly related to the display calibration? I set mine to Wide Amoled Gamut under Advanced, but then I noticed how "saturated" the pictures appear when compared to either Vivid/Natural mode. The reason I ask is because this never happened on my Oneplus 5. And I did try it fiddle around with the calibration and photo colour when I had it.
  10. Georgeoneplus7pro
    Jelly Bean Nov 10, 2019
    Georgeoneplus7pro , Nov 10, 2019 :
    Of course, if you deleted delvik, your life became perfect.
    B k and Netsky60 like this.
  11. U1568742994042
    Donut Nov 10, 2019
  12. kunparatarak
    kunparatarak , via OnePlus 7 , Nov 10, 2019 :
    There is a bug in shelf. Sometimes when I try to scroll up/down in shelf content, it doesn't work. To activate the shelf perfectly every time I need to turn off/on the shelf in the settings.
  13. Dirk66
    Gingerbread Nov 10, 2019
    Dirk66 , via OnePlus 7 Pro , Nov 10, 2019 :
    be glad you didn't get it yet. bugs bugs. released way to soon. some wanna revert to pie again and you want A 10.
  14. Ruchit4197
    Ruchit4197 , via OnePlus 7 , Nov 10, 2019 :
    after update 10.0.1 my oneplus 7 habe same fix issues
    ,after finger print open ..i still face finger print option n not don anything that area..did not type any msg propaly ...fix this issues
  15. Mr._Stark
    Donut Nov 10, 2019
    Mr._Stark , via OnePlus 7 Pro , Nov 10, 2019 :
    does anyone know the reason for the bugs?
    is it due to Google and the Android 10?
  16. Dirk66
    it's always like that, going from one major to another upgrade/update. it's normal but OnePlus rushed it out to be the first. now lots of users are stuck with bugs and OnePlus has tons of work to do. A shame when you promise but can't deliver . that's my only complaint....rushed it out to soon.
  17. yiabol
  18. allwars278
    allwars278 , via OnePlus 7 Pro , Nov 10, 2019 :
    i have problems with the auto bright sensor and bluetooth with some devices, like headphones.
    yesterday Spotify freeze I'm the system and I have to reboot the system. my phone is not rooted and neither get beta software.
    jstiggie likes this.
  19. B1566149854986
