659
  1. Syed_Mutaheer
    Eclair Oct 12, 2019
    Syed_Mutaheer , Oct 12, 2019 :
    guys dis new update is a Minor one no more big improvement hd done in dis update and the camera quality still remain the same so don't get excited. keep ur curiosity for next major update.
  2. E1559998861602
    Cupcake Oct 12, 2019
  3. anchits28
    Eclair Oct 12, 2019
    anchits28 , via OnePlus 7 Pro , Oct 12, 2019 :
    Hello Everyone,
    I'm on latest OxygenOS 10.0.1 and all the issues reported by me in the previous OS 10.0 are not resolved. I'm using One Plus 7 Pro and I'm from India. I know OP team updated us that they have fixed various bugs. But if below example of bugs are not fixed then I don't know which bugs they have fixed in this release.
    I have done clean install and full cache is wiped before using.
    1st Issue: Blur photo in Speed Dial. The contact picture got uploaded successfully but when I open that Contact in Speed Dial, I'm getting below photo. Yes its Captain America photo but totally blurred.
    2nd Issue: Someone please remove the gap between the navigation bar and keyboard. I know many have reported but it's kinda of annoying.
    3rd Issue: This is the biggest one. Issue with Android Auto. The moment I plug wire in USB type C of Android Auto the Black theme gets updated to white. After sometime of usage Phone becomes hot. Even after disconnecting the phone theme will remain white.
    Check my last screenshot and name of the theme. Its Naunced Dark but everything is white. I again need to reset the theme to Dark to make it work.
    After the update of 10.0, I have received two updates od Android Auto from Google, so definitely this bug is not from Google.
    U1558552994291 and Eliott C like this.
  4. SahilNKhan
  5. IamMitesh
    Gingerbread Oct 12, 2019
  6. Swejuggalo
    KitKat Oct 12, 2019
    Swejuggalo , Oct 12, 2019 :
    Many patched things is proof of concepts and most often by physical access to the phone. They update most often bi-monthly. Montly is a bonus in this case
  7. zli258
  8. Abhi Dahiya
    Ice Cream Sandwich Oct 12, 2019
    Abhi Dahiya , via OnePlus 7 , Oct 12, 2019 :
    Benchmark scores change everytime you do them. Infact just after an update it will be lesser. Learn about how these things work.
    You are the only one with this issue. Either you have enabled forced dark mode in developer options or you need to clear cache or factory reset your phone as it was a big update.
    You have to remove fingerprints and re register them. Usually they work slower after big updates.
    That white bar is not bug. It is also in iOS so that it's easier to type on keyboard in long phones.
  9. jrd76
    jrd76 , via OnePlus 7 , Oct 12, 2019 :
    CVE-2019-3568 exploits binder.c, no physical access required
  10. Swejuggalo
    KitKat Oct 12, 2019
    Beta channel rocks (for me atleast [e]1f609[/e])
    GraveDigger176 likes this.
  11. K1568464729649
  12. Eliott C
    Eliott C , via OnePlus 7 , Oct 12, 2019 :
    still not !!
    F_Chirag_Parmar_xxWJ likes this.
  13. Swejuggalo
    KitKat Oct 12, 2019
    Was a big security flaw months back. Don't recall what it was. No physical access there either. But it was never proved that a real breach had happened during the time of that article.
  14. D1570904295153
  15. G_Bogdan_Mitrica_(Fotogr
    G_Bogdan_Mitrica_(Fotogr , Oct 12, 2019 :
    no, it doesn't buy in my opinion, stable 10.0.1 is better than OB3
  16. Sakib4
    Sakib4 , Oct 12, 2019 :
    *adaptive brightness issue solved
    *contact no image quality issue solved
    *black screen issue in pubg solved
    *some messenger bugs are solved
  17. Pa_One
    Eclair Oct 12, 2019
  18. L1570027242203
  19. MohammadNegm
    MohammadNegm , Oct 12, 2019 :
    are there any customization options to turn notification toggles into black ??
