660
  1. Federico Prencipe
    Honeycomb Feb 13, 2020
    Federico Prencipe , Feb 13, 2020 :
    The First screenshot is about the Google app, isn't it?
    If so I have an older version but beeing a staged rollout it's normal.
    I can't find the page of the second screenshot, on the official post they say to open the Google settings and then open the assistant but I have the usual 4 tabs you/assistant/services/home. I don't know if the names are the same, I'm trying to translate them from italian, maybe it's not a literal translation.
    Shalin235 likes this.
  2. Shalin05 , via OnePlus 7 Pro Nebula Blue , Feb 13, 2020 :
    Please try the following Steps:-
    1) Open Google App
    2) Go to More Options and Select Settings
    3) In Settings Go to Google Assistant
    4) Select Assistant Tab
    5) In that in Assistant Devices select phone
    6) In the Personalization Tab Select Ambient Mode.
    Federico Prencipe likes this.
  3. Federico Prencipe
    Thank you. I've found the setting, I already have it.
    I'll try it as soon as possible even if I don't think I will use it, it has a lot of potential problems, first of all OLED burning showing a static image.
  4. Abdul_Aziz544
    Froyo Feb 13, 2020
  5. Federico Prencipe
    Honeycomb Feb 14, 2020
  6. RainyMoonShadow , via OnePlus 7 Pro , Feb 14, 2020 :
    they have on the Google ABD post
  7. Hemangb2
    Vishwa017 likes this.
  8. V1570000338270
    Eclair Feb 14, 2020
    A1560648267550 likes this.
  9. A1560648267550
    Gingerbread Feb 14, 2020
  10. charmingash
  11. stangweb
  12. stangweb likes this.
  13. Glady c sekhar
    Cupcake Feb 15, 2020
  14. pritamashwani
    Gingerbread Feb 15, 2020
  15. Biswajit Padhi likes this.
  16. G1559901600613
    Eclair Feb 15, 2020
  17. Ant91
  18. Federico Prencipe
    Honeycomb Feb 16, 2020
  19. L1541631867700
    Cupcake Mar 9, 2020
    L1541631867700 , Mar 9, 2020 :
    Having real trouble with the oneplus6t just dropping out of 4g and needing to have to reset my phone after this update. Any known fix ?
