658
  1. Z1563635775454
    Cupcake Oct 12, 2019
    Z1563635775454 , Oct 12, 2019 :
    Recently got the update. When I go to recent apps, I can't go back to home without killing an app.
    Could be I don't know how, or could be a bug. Help please.
  2. S1558269980867
    Eclair Oct 12, 2019
    S1558269980867 , Oct 12, 2019 :
    Is the option for the two button navigation bar still gone? In the beta they replaced it with that annoying side swipe option.
  3. ShuvraC
    Froyo Oct 12, 2019
    ShuvraC , Oct 12, 2019 :
    is Work-Life Balance (India only) this option is present in this 10.0.1 update ?...any one from india pls tell me......i update but i dont find this option inside utilities option
  4. NischalD9
    Donut Oct 12, 2019
    NischalD9 , via OnePlus 7 , Oct 12, 2019 :
    that was the whole point ...they even mentioned that in the launch event October 10 saying the animation remains for a sec even after unlocking.....it was to give a smoother look than ubrupt unlock.
  5. hally79
    Froyo Oct 12, 2019
    hally79 , via OnePlus 7 Pro , Oct 12, 2019 :
    download oxygen updater from playstore... download the update and update via the local update tab...job done
  6. Nicck_BL
  7. UPrashar
    UPrashar , via OnePlus 7 , Oct 12, 2019 :
    Even a software based one will be great on 7 and pro too
  8. B k
    Ice Cream Sandwich Oct 12, 2019
    B k , via OnePlus 7 Pro , Oct 12, 2019 :
    yes.. i think its still a small bug. not solved yet. atleast not for me. maybe next update it gets solved
  9. Swejuggalo
    KitKat Oct 12, 2019
    Swejuggalo , Oct 12, 2019 :
    You will continue to get normal OTA even after using it
    NischalD9 likes this.
  10. NischalD9
    Donut Oct 12, 2019
    no, it's not a bug...it's intentionally designed by one plus team!
  11. B k
  12. GraveDigger176
    Gingerbread Oct 12, 2019
  13. ShuvraC
    Froyo Oct 12, 2019
  14. B k
  15. Yash_0114
  16. Demon_hunter , via OnePlus 7 Pro Mirror Gray , Oct 12, 2019 :
    you can disable it if you don't like
  17. NischalD9
    Donut Oct 12, 2019
    have u used oxygen updater before? cause to be honest I am super scared ..cause I was previously on beta version...and when beta 2 was released, they announced that official updates will be stopped and only beta will be received..which kinda was pissing off...so I had to use wipe file and downgrade back to pie...so I'm scared to experiment..so I've been waiting for it to come via OTA , cause wat if loose the OTA if I use oxygen updater..
  18. Chief Jems
    Froyo Oct 12, 2019
    Chief Jems , via OnePlus 7 , Oct 12, 2019 :
    oxygen updater diye update more felchi bai. apni chaile korte paren. era late Kore....
  19. 404.php
    Honeycomb Oct 12, 2019
    404.php , Oct 12, 2019 :
    Running 10.0.1. Still having the dark mode issue where it doesn't stay "dark". Some elements of the theme such as the launcher background and Settings switched back to white after a while.
  20. Y1569675772066
    Y1569675772066 , Oct 12, 2019 :
    root kora lagbe naki?
