660
  1. James 007
    Gingerbread Oct 13, 2019
    James 007 , via OnePlus 7 , Oct 13, 2019 :
    ob3 And OOS 10.0.1 it's a same thing just different name of it with bit of luck we may see stable version of OOS by 10.0.3 for now be happy on 9.0 aka pie
    S1558388618694 likes this.
  2. ianshul9 , via OnePlus 7 Mirror Gray , Oct 13, 2019 :
    i have downloaded the incremental update of oneplus 7, what does that mean?
    how different is it from the full update
  3. S1558388618694
    S1558388618694 , via OnePlus 7 Pro , Oct 13, 2019 :
    You cannot but if you can disable the "Google app" that's in the device so Google assistant won't work at all. I tried it G it works
    Stako187 likes this.
  4. Stako187
    Stako187 , via OnePlus 7 Pro , Oct 13, 2019 :
    u mean force stop it?
  5. _m.syahir
    Cupcake Oct 13, 2019
  6. S1558388618694
    I think it means when you download, it will only download the new features that are fixed, instead of the full update
    ianshul9 likes this.
  7. S1558388618694
  8. ianshul9 , via OnePlus 7 Mirror Gray , Oct 13, 2019 :
    installation in progress, hoping everything to work fine
  9. Stako187
    how to disable it with 3rd party app or...?
  10. S1558388618694
  11. TheMysticalShaman
    Honeycomb Oct 13, 2019
    TheMysticalShaman , via OnePlus 7 Pro , Oct 13, 2019 :
    While OxygenOS 10.0 rolled out to the OnePlus 7 Pro on September 21st, the company needed to halt the update due to numerous bugs. Now the company has remedied that with the 10.0.1 version of the OS.
    Read more at MobileSyrup.com: OxygenOS 10.0.1 rolling out to OnePlus 7 Pro with bug fixes.
    I got this update using Oxygen Updater. This update is a lot better. Still some problems with gestures. Especially when trying to swipe up within an app for recent apps. Taking just a few tries compared to the previous OxygenOS 10.0.0 it was basically impossible. I will stick with the fixed navigation until I can get recent apps with first swipe within an app
  12. S1558388618694 likes this.
  13. TheMysticalShaman
  14. patrick.h.day
    Froyo Oct 13, 2019
    patrick.h.day , Oct 13, 2019 :
    If anyone is having issues with Oxygen OS post install, may I suggest booting into recovery and wipe everything. I was encountering slow cell/wifi data speeds, and since all my stuff backs up automatically anyway, I just wiped the phone and set it up as if it were new. Yeah its a little inconvenient, but my phone runs flawlessly now. Worth it imo.
  15. L1562699793537
    L1562699793537 , Oct 13, 2019 :
    hello after install 10.0.1 i do not have message icon on the main screen i only can do shortcut to messages but do not know how add normal message icon to the main screen also maybe this is a bug but system icons do not change collors i set black theme and red color but system icons are blues -> in beta 2 this was ok thanks for fedback
  16. Nico KB
    Eclair Oct 13, 2019
    Nico KB , Oct 13, 2019 :
    Will the OnePlus 7pro receive a macro mode and OIS in 4k recording?
    Any improvements to the inbuilt SIP stack in Android 10?
  17. Poussin16
  18. nueveaguilas
    nueveaguilas , via OnePlus 7 , Oct 13, 2019 :
    I say I have the same problem in WhatsApp with the audios the screen turns off greetings friend from Argentina
    W1542783177891 likes this.
  19. Weirdpepperguy , via OnePlus 7 Pro T-Mobile , Oct 13, 2019 :
    I believe that India is OnePlus number one market.The US is 2 or 3, considering how the UK got both the 7 Pro and the 7T Pro, I think that the US is number 3
  20. Spiskur
