37
OxygenOS 10.0.10 and 10.3.4 [India] for the OnePlus 7T Pro
  1. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 9, 2020 :
    I'm refering to the avoidance of Oxygen Updater and at the same time gladly use links to download the exact same stock firmware.
  2. N1574330972162
    Eclair Sep 9, 2020
    N1574330972162 , Sep 9, 2020 :
    that's not something I do
  3. Oleg Trxnv
    Donut Sep 10, 2020
    Y.Singh, stefsims and edo_me like this.
  4. KiranMallepally
    Cupcake Sep 10, 2020
    KiranMallepally , via OnePlus 7T Pro , Sep 10, 2020 :
    Will you face this problem ? If not try once on creating guest user and install whatsapp then make voice or video calls
    Please share your experience Thank you
  5. N1574330972162
    Eclair Sep 10, 2020
    N1574330972162 , Sep 10, 2020 :
    I know, right? Must be a lot of work with Android 11 on other devices going on at the office (home office).
    edo_me likes this.
  6. M1579381619992
    Cupcake Sep 13, 2020
    muharrem1961 likes this.
  7. Oleg Trxnv
    Donut Sep 13, 2020
  8. stetre76
    Gingerbread Sep 14, 2020
    stetre76 , Sep 14, 2020 :
    When it's ready...
  9. G_ak_video_yWbC
    Cupcake Sep 15, 2020
  10. ravr
    Eclair Sep 15, 2020
    ravr , via OnePlus 7T , Sep 15, 2020 :
    Are we expecting another beta update anytime soon or will there be Oxygen OS 11 update only after some time? 🤔🤔
  11. Eth2003
  12. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 15, 2020 :
    You might want to update manually from homepage instead. Support, Software upgrades.
    Some people seems to get delays like this every now and then of some reason
  13. Eth2003
  14. Eth2003
  15. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 15, 2020 :
    If you checked Md5 of the file got the same Md5 as listed on homepage then you atleast know the update is OK.
    I guess a reset might help in that case.
  16. Eth2003
    Eth2003 , via OnePlus 7T Pro , Sep 15, 2020 :
    Yeah idk maybe I'll just wait for the update to come to my phone
  17. Eth2003
    Eventually it will come to my phone in settings right?
  18. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 15, 2020 :
    Yes. It should. Normally it should show up within 2 weeks from release date though... But something is acting strange if it even refused manual update.
    If it still refuses giving you updates you might need to consider a reset to see if that helps.
