37
OxygenOS 10.0.10 and 10.3.4 [India] for the OnePlus 7T Pro
  1. Atantyo
    Gingerbread Aug 7, 2020
    Atantyo , via OnePlus 7T Pro , Aug 7, 2020 :
    Dude seriously? 3 months? It takes u 3 months for an update? Oneplus clearly not as fast as before in updates
    Before now i use 7T pro, i use op 3-3T-6-7-7 pro. When at op3-3T and 6, i get updates at least once in 2 months even after a year the phone realease.
  2. Nani@KKR
    Donut Aug 7, 2020
  3. Avdeshraghu0
    Eclair Aug 7, 2020
  4. R1587039481912
    Cupcake Aug 7, 2020
  5. ktk89
    Honeycomb Aug 7, 2020
    ktk89 , Aug 7, 2020 :
    After the update naturally battery backup takes a hit..need some cycles to actually give a verdict
    A.murali likes this.
  6. Sam peteti , via OnePlus 7T Frosted Silver , Aug 7, 2020 :
    We are getting updates every Two months bro.
    tal_sarid likes this.
  7. E1576836040518
    Cupcake Aug 7, 2020
    E1576836040518 , via OnePlus 7T Pro , Aug 7, 2020 :
    Update is issued after exactly 2 months
  8. JiBi
  9. domendrasahuuu
    Cupcake Aug 7, 2020
  10. Sunny4415
    Cupcake Aug 7, 2020
    Sunny4415 , via OnePlus 7T , Aug 7, 2020 :
    If you install the update file using oxygen updater, don't know the reason but I got the ota update twice lately once I installed through oxygen updater app. More over its not official app
    So I waited for few days tried with vpn mode and what not.
    Oxygen updater app generally uses the vpn method and downloads the ota update. Not sure is it really worth for me to update my one plus 6T and 7T.
    So, if you want to get the ota need to wait until your phone recognises that you got an update or try the OnePlus.in website software upgrade section and download your official stable rom and flash it through local upgrade option.
  11. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Aug 7, 2020 :
    In what way does it use an VPN?
    Oxygen Updater collects filenames from real OTAs from other users with the app. Then the devs verifiy and puts it out for everyone to download, directly from Oneplus servers and verifies md5 hash after download for you. It also puts the file directly under root folder and with correct file extension, ready for local upgrade strait away.
    However it's up to the user to verify what settings in the app they use. If they change something or its incorrectly detected of some reason you may end up flashing incorrect region. You may also use it to change to open beta relese channel.
  12. ZKoSV
    Donut Aug 7, 2020
    Tedinetto likes this.
  13. kumar93011
    Eclair Aug 7, 2020
    kumar93011 , via OnePlus 7T , Aug 7, 2020 :
    As a matter of fact, battery life has decreased after the update!
  14. tanaye1013
  15. Drishtant Kumar
    Donut Aug 7, 2020
