107
OxygenOS 10.0.10 [EU] and 10.3.7 [India & Global] for the OnePlus 7 Pro and OnePlus 7
  1. pvs007
    Cupcake Dec 3, 2020
  2. surajit20
    Eclair Dec 3, 2020
    surajit20 , Dec 3, 2020 :
    Facing issue in network after update.sim 1 tower has been obsolate frequently.
    Linkin1994 likes this.
  3. Rahultech
    Eclair Dec 3, 2020
  4. J1566423719985
    Cupcake Dec 3, 2020
    J1566423719985 , Dec 3, 2020 :
    phone was heating and battery was being so bad after this update onepluse could fix this one please
  5. R.Peter
    Ice Cream Sandwich Dec 3, 2020
    R.Peter , via OnePlus 7 Pro , Dec 3, 2020 :
    Just out of curiosity, didn't you play games when you experienced those things?
  6. mrmatrix
    Eclair Dec 4, 2020
    mrmatrix , via OnePlus 7 Pro , Dec 4, 2020 :
    Update oneplus game on play store.
  7. Jrocci
    Honeycomb Dec 4, 2020
  8. J1566423719985
    Cupcake Dec 4, 2020
    J1566423719985 , Dec 4, 2020 :
    no i have uninstalled pubg also after the update it was not fine mine was onepluse 7
  9. Ralph Reagan Quijada , via OnePlus 7 , Dec 4, 2020 :
    I rolled back my oneplus 7 to android pie from android 10 few days ago. Im just wondering why there is no any kind of updates just in case i want to update/upgrade again to android 10. Should i wait few more days to receive some updates? Because i just rolled back few days ago.
    I will wait if the updates will come after few days in the settings, but if not should i manually update it from here?
    Thanks for the answer guys I'll appreciate it.
  10. Artemus.
    Community Hero 2020 Dec 4, 2020
    Artemus. , Dec 4, 2020 :
    You can't go from 9.x to 10.0/3.x, you have to go from 9.x to 10.0.1 to 10.0/3.x which can only be done via Oxygen Updater.
  11. GokulLee
    Gingerbread Dec 4, 2020
  12. Ralph Reagan Quijada , via OnePlus 7 , Dec 4, 2020 :
    So you mean that 10.0.1 will never come in the settings even i wait for few days. And i need to manually upgrade to 10.0.1 using oxygen os updater. Thankss
  13. V1570381467577
    Cupcake Dec 4, 2020
    V1570381467577 , Dec 4, 2020 :
    Hi. When i turn mobile vibrate to ring mode its not working... When i restart mobile able to see in ring mode.. Again if i make vibrate not able to turn to ring mode... I need to restart mobile... Is it software issue? I m using one plus 7
  14. Artemus.
    Yes. Because the OTA is looooong over that you must manually update to 10.x (and Oxygen Updater makes it easy).
    Ralph Reagan Quijada likes this.
  15. ABDULLAH.ASHOUR
    Cupcake Dec 4, 2020
  16. akks
    KitKat Dec 4, 2020
    akks , Dec 4, 2020 :
    Less likely to be update related. I've no issues on my OnePlus 7 pro. Try clearing system cache, if still persisting, hard reset your device and set it up again as a new device, instead of completely restoring the entire backup.
  17. Gokul7373
  18. mlulic
    Ice Cream Sandwich Dec 4, 2020
    mlulic , Dec 4, 2020 :
    Because I fail to see how your post whining to get Android 11 has any influence on 1000 others who whine as well, and yet, everyone knows commenting has no effect on development speed.
    I know, right? Let's rush them to get it NOW, and 10 mins after update installation, let's whine about bugs. SMH...
    I could not agree more.
    Remember back in the day when a mobile phone, Nokia 3310 for example, had no updates? :D
