146
OxygenOS 10.0.11 and 10.3.3 [India] for the OnePlus 7T
  1. L1571448340101
    Donut Jun 30, 2020
    L1571448340101 , via OnePlus 7T , Jun 30, 2020 :
    Will one plus 7T (India) support to dual channel network acceleration or dual wifi connectivity through any future update. I am asking this because the network specs are the same as other devices support to dual channel network acceleration and very exited for the feature.
  2. airmotovlogs
    Gingerbread Jun 30, 2020
    airmotovlogs , via OnePlus 7T , Jun 30, 2020 :
    Hi Guys...am from New Delhi, India and own a Oneplus7T Glacier Blue. After following a lot of discussions here and some helpful hints n tips, bricked my phonento the following version with the features n updates as mentioned and Touchwood, its working fine, with no drastic dip in performance. I downloaded it via the Oxygen updater App. Additionally theres a BT dependant Covid Tracker that shows option that now shows up in the menu . Though am not using that particular feature.
    Adarsh792000 likes this.
  3. Nevlit221
    Cupcake Jun 30, 2020
  4. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jun 30, 2020 :
    It's not the update. It is the Oneplus Gallery app. Uninstall updates, halt automatic updates on Play Store until they fix it.
  5. Nevlit221
  6. airmotovlogs
    Honestly the 720p only 960fps feature is all crap... I tried in different lighting scenarios...everytime it returned a crsppy soft looking video...totally unusable in my opinion
  7. TejanHazarika
    TejanHazarika , Jun 30, 2020 :
    Dual Channel Network acceleration feature is there in the Beta 5 version itself, don't know when will they (OnePlus) release it in the Stable version
    L1571448340101 likes this.
  8. CooL2000
  9. M1587969516771
    M1587969516771 , Jun 30, 2020 :
    Hi, post the update my 1+7T drains battery drastically. This is my first experience of one plus in my entire mobile carrier, when i bought this I use to get atleast 1/2 battery life now it s lesser than that. Mobile is awesome but s it with the update issue?
    Pls help
  10. airmotovlogs
    The steps might sound funny but works in favour and saves battery drainage at least on my 7T.. 1. Use dark Wallpapers, dark screensavers 2. use Dark Mode (if youre not, just in case) 3. Use 60 htz refresh rate 4. Use Automatic Display brightness (if youre not) 5. Make sure battery optimizer is on
  11. AzureB1te , via OnePlus 7T Glacier Blue , Jun 30, 2020 :
    Hey ! I'm a new guy in here. My internal updater shows that I'm running the latest version,even tho that's 10.0.8 for me. I am on the EU build,using a 7T,afraid of something being wrong with my device. Any help?
  12. karthikeyans1977
    Gingerbread Jul 1, 2020
    karthikeyans1977 , via OnePlus 7T , Jul 1, 2020 :
    @oneplus_support @OnePlus_IN @PeteLau @getpeid While receiving incoming calls, the company name from stored contacts (when you store name, no. and company in respective fields) is not displaying.That feature is available on OP 5 with the latest update. When will it come to OP 7T?
  13. karthikeyans1977
    While receiving incoming calls, the company name from stored contacts (when you store name, no. and company in respective fields) is not displaying.That feature is available on OP 5 with the latest update. When will it come to OP 7T? Been asking for this feature for nore than three years now and in between switched to iPhone just for this and returned back to OP. Glad to see it is being included as a feature for OP 5 users but will be great if it can be made available for everyone else as well.
  14. ArunNarasimman
    Cupcake Jul 1, 2020
  15. trnsharma
    Cupcake Jul 1, 2020
    trnsharma , Jul 1, 2020 :
    I recently purchased 1+ 7t 256gb variant and device was on 10.0.3 version. Everything was working fine. Yesterday I updated to 10.3.3 and cleared the cache from boot menu. Now I am facing problem with fingerprint scanner. It was working fine in all scenario prior to update. Now sometimes I wont do anything, just keep glowing as I put my registered thumb to unlock. I have to wake up to screen again for the fingerprint to work. If I move my thumb quickly and than again I want to unlock by placing my thumb again, screen wont unlock. Again I have to wake screen again to unlock. This all is happening on clock screen which is woken up by single or double tap on screen, not bu power button. Everything was working fine on this clock screen prior to update. Developer team, kindly resolve the issue as my device is only 5 days old and I am new to 1+7.
    triden29 likes this.
  16. Varyan , via OnePlus 7T Frosted Silver , Jul 1, 2020 :
    just remove your previous fingerprint data & add it again & check whether its working fine. you can also add same fingerprint twice to improve its accuracy
  17. trnsharma
    Cupcake Jul 1, 2020
    I did remove and added back but still no improvement.
  18. kamsal
    Cupcake Jul 1, 2020
  19. B1593009512731
    Cupcake Jul 1, 2020
    B1593009512731 , Jul 1, 2020 :
    hi,
    I am new to OP7T with OS 10.0.11. Could it be possible to have the APP folder with 3x3 icons instead of 2x2?
    Thanks a lot.
    Franco
