76
OxygenOS 10.0.12 and 10.3.4 [India] for the OnePlus 7T
  1. deepakavasthy
    Donut Aug 9, 2020
    deepakavasthy , Aug 9, 2020 :
    I feel like sound from speakers is a bit on a lower side post this update. Anyone else facing this issue ?
  2. iamabhijeetpanda , via OnePlus 7T Glacier Blue , Aug 9, 2020 :
    The cloud icon i have noticed from beta 5. I think this is not new.
  3. am_saury
    Cupcake Aug 9, 2020
    am_saury , via OnePlus 7T , Aug 9, 2020 :
    My Home screen has gone blank after the update. Only the wallpaper is visble. There no widgets, App icons, Quick access tabs visible on the homescreen. The OnePlus App launcher crashes all the time. I have go though settiings tab on the notification tray or through Google Assistant to access any app or settings. Please help!!
  4. bramgoodwin
    Gingerbread Aug 10, 2020
    V1578741403126 likes this.
  5. faislo
    Donut Aug 10, 2020
    PriyeshPatil likes this.
  6. Ruteesh
    Eclair Aug 10, 2020
  7. PriyeshPatil
  8. PriyeshPatil
    PriyeshPatil , via OnePlus 7T , Aug 10, 2020 :
    I have problem connecting to my bluetooth headset everytime. Also when it gets connected the mesia volume goes down to zero. Anyone else having same trouble ?
  9. J1583773694113
    Cupcake Aug 10, 2020
    J1583773694113 , Aug 10, 2020 :
    Im facing couple of major issues so far with this update. the bluetooth connectivity and battery draining issue.. My bluetooth is getting freezed within short period of time. Need to reconnect every time to get working.. Also battery is getting drained every 2 mins with normal usage. I shouldn't have go for this update, everything was working fine earlier with good battery life.. Regretting now.. ☹️☹️
    Achman likes this.
  10. jaimil thakkar
  11. arunsagarsk
  12. Alexander Kazko
    Froyo Aug 10, 2020
  13. Aiswar
  14. SteFaNos123
    Froyo Aug 10, 2020
  15. Startech17
    Startech17 , Aug 10, 2020 :
    Hello. Hows battery life for you on .12? Would you mind testing to see if the gesture bar is randomly showing up even when set to hidden?
  16. prabhatspatil@gm
    bubbleman06 likes this.
  17. bramgoodwin
    bramgoodwin , via OnePlus 7T , Aug 10, 2020 :
    Battery Life same, which means easily all day, even with heavy usage. Yes, hide gesture bar in settings, works. But, never bother me. Kind of grew fond, may bring back. I'm impressed I got it so soon, since normally 3_4 weeks after drop. OP7T is best phone yet. Impressed with OP so far.
  18. mohammed_220404
  19. bramgoodwin
    Could be up to 4 weeks. Got this update in 4 days, but last 2 updates 25, 27 days after drop. BTW, nothing earth shattering, mostly bug fixes.
  20. PriyeshPatil
    Just update it via Oxygen Updater app from Playstore... If you can... Or else wait for their cycles of 14 days batches...
