26
OxygenOS 10.0.12 and 10.3.6 [India] for the OnePlus 7T Pro
  1. Tokolozi
    Nougat Nov 7, 2020
  2. Paras.OnePlus
    Cupcake Nov 7, 2020
    Paras.OnePlus , via OnePlus 7T Pro , Nov 7, 2020 :
    Check battery optimization settings of your impacted applications. this could also happen if ur cell is in power saving mode.
  3. superplus
    Head Moderator Head Moderator Nov 7, 2020
    superplus , Nov 7, 2020 :
    Hi I'm glad that you're happy to have received the update, but please have a look at the forums' Terms & Rules (https://forums.oneplus.com/help/terms) and try to comply with them by finding an existing thread to post in, as pointed out by @Tokolozi, rather than creating a thread of your own. In your device's section you will be able to find official update announcement threads, as you can see the roll-out of the 10.3.6 version for 7T Pro was announced on the 22nd of October, including a change-log. Please in the future post excitement in such threads or in the Software update excitement thread, thank you.
    Thread merged with the official update announcement thread.
  4. pradeeprao1989
    Eclair Nov 7, 2020
  5. us4ak
    Cupcake Nov 8, 2020
    us4ak , via OnePlus 7T Pro , Nov 8, 2020 :
    Bluetooth scanning (location) turns ON automatically even upon disabling manually. Happens like within an hour of disabling. I haven't installed any new app after the 10.3.6 update. So, clearly it's the update causing this issue.
    Anyone else facing the same problem?
  6. sainath23
    Cupcake Nov 8, 2020
    sainath23 , via OnePlus 7T Pro , Nov 8, 2020 :
    I have updated my OnePlus 7T Pro to 10.3.6.HD01AA. But it has introduced new bug. I cannot open my phone/dialer app. Whenever I try to open it, it simply crashes. Tried clearing it's cache and storage but still does not work. Please help.
    Amritashya likes this.
  7. Nighthawk777 , via OnePlus 7T Pro , Nov 8, 2020 :
    Yes
    Bluetooth scanning tends to enable on it's own again and again even after disabling it manually.
    Edit:- but this problem is from beginning when i bought this phone a year ago, i don't think this is related to 10.3.6 specifically.
    us4ak likes this.
  8. Nighthawk777 , via OnePlus 7T Pro , Nov 8, 2020 :
    I don't have any issue with OnePlus message app.
    It's working perfectly fine.
    If problem continues then install Google message app.
  9. H1603724647025
    Cupcake Nov 8, 2020
    H1603724647025 , Nov 8, 2020 :
    Hi Team,
    I have observed that this 10.3.6 is draining the battery faster than previous version. Please fix this ASAP.
    us4ak likes this.
  10. Raj1007
    Eclair Nov 8, 2020
  11. UnicornZ
    Ice Cream Sandwich Nov 8, 2020
    UnicornZ , via OnePlus 7 Pro Nebula Blue , Nov 8, 2020 :
    An work around for alarm not ringing issue.. delete all existing alarm and set new one. It should work.
    Regarding Gboard haptic, did u try to change the intensity under Gboard setting.
  12. UnicornZ
    Latest Download files are not yet updated in support page. Third party app is there to do that,but won't suggest.
    If you want to switch to beta, instructions are provided in beta thread.
  13. Raj1007
    Eclair Nov 8, 2020
    Raj1007 , via OnePlus 7T , Nov 8, 2020 :
    I want to switch beta version to stable version but the 10.3.6 update is not available on support page !
  14. UnicornZ
    Unfortunately they will upload it only after its recieved by everyone via OTA
  15. Raj1007
    Eclair Nov 8, 2020
    Is there any fix date or any astimated date for arriving the update ?
  16. UnicornZ
  17. Raj1007
    Eclair Nov 8, 2020
  18. lucifer_angel
    Gingerbread Nov 8, 2020
    lucifer_angel , via OnePlus 7T Pro , Nov 8, 2020 :
    Yes I'm also facing this issue. Due to this battery life is slightly impacted
    For me previously this issue was not there. In this update only even I disable Bluetooth scanning, it turns itself on after some time.
    OnePlus needs to fix this in next update
    us4ak likes this.
  19. The great dane likes this.
