27
OxygenOS 10.0.12 and 10.3.6 [India] for the OnePlus 7T Pro
  1. L1603810372849
    Cupcake Nov 11, 2020
    L1603810372849 , via OnePlus 7T Pro , Nov 11, 2020 :
    I got 10.3.6 updated but post that call waiting option got disabled...now whoever calling while I am on call, getting not reachable...I'm not able to enable that option as well...Is ther any solution for the same....?Anybody facing tthis issue..?
  2. H1603724647025 likes this.
  3. WEBSDCOOL
    Gingerbread Nov 11, 2020
    WEBSDCOOL , via OnePlus 7T , Nov 11, 2020 :
    You can disable it. Just go to phone app and click on the 3 dot icon on upper right hand side and then click on settings.
  4. Nighthawk777
    Froyo Nov 11, 2020
    Nighthawk777 , via OnePlus 7T Pro , Nov 11, 2020 :
    No, I don't have that issue
    You can do this though
    Open the Phone/Dialer app.
    Tap on the Options button (3 vertical dots at top right) and choose Settings.
    Then select call settings, tap sim 1 or sim 2
    Then tap additional settings, here you will see option of call waiting and enable if it is disabled.
  5. J1601886364022
  6. Amritashya
    Froyo Nov 11, 2020
    Amritashya , via OnePlus 7T Pro , Nov 11, 2020 :
    Sorry bro I am not facing this issue. May be a random bug.
  7. L1603810372849
    Cupcake Nov 12, 2020
    L1603810372849 , via OnePlus 7T Pro , Nov 12, 2020 :
    Bot not able to enable that call waiting option... getting SIM error. It was working before installing latest patch.
  8. Z@f@r
    Z@f@r , Nov 12, 2020 :
    Earlier i was on 10.3.4(india) and everything was working fine. After doing 10.3.6 update my alarm stopped ringing all the time, it only vibrates but no sound at all. Whoever on 10.3.4 dont update to this version. This version suppose to resolve the alarm issue but in my case it created one. iam totally dissappointed with this update.
  9. Z@f@r
    dont update. it has alarm ringing issue. i was also on 10.3.4 i dint had any issue but after the update the issue came
  10. Ridhav Aggarwal
    Froyo Nov 12, 2020
    Ridhav Aggarwal , via OnePlus 7T , Nov 12, 2020 :
    Am i the only one, or anybody else also facing the issue of fingerprint not registering while the phone is in ambience display. I mean when the phome is locked and i try to unlock it as the phone turn the ambience display on, the sensor does not register my thumb or any other registered finger. I have to click the power button, the lock screen lights up, only then the sensor registers my thumb.
    P.S. - It does not happen all the time but quite often.
    triden29 likes this.
  11. palash1010
    Eclair Nov 17, 2020
    palash1010 , Nov 17, 2020 :
    it's been long that I updated my phone to 10.3.6 and never have I ever seen a good battery backup.
    Just look at the stats here. for no reason the better is getting used.
    SOT of 4-4.5 hours is too bad!
    Is there any setting that I'm missing that can help restore the battery performance?
  12. VAIBHAVMAKWANA
    Eclair Nov 17, 2020
    VAIBHAVMAKWANA , via OnePlus 7T , Nov 17, 2020 :
    Yes bro u can accept this one tere is no bugs in 10.3.6 update
  13. LekkalaSuryaTeja
    Cupcake Nov 17, 2020
  14. Raj1007
    Eclair Nov 23, 2020
    Raj1007 , via OnePlus 7T , Nov 23, 2020 :
    Bro now , did you get the October month's security patch ?
  15. ktk89
    Honeycomb Nov 23, 2020
    ktk89 , Nov 23, 2020 :
    Still on September...no updates
    Raj1007 likes this.
  16. Adnan2020
    Cupcake Nov 23, 2020
    Adnan2020 , Nov 23, 2020 :
    Try to do a factory reset, then see. Or if you won't, make the resolution FHD+, and see what you'll get.
  17. ktk89
    Honeycomb Nov 24, 2020
    ktk89 , Nov 24, 2020 :
    Yes mine...can't hold my phone without case
    Z1593695516936 likes this.
