63
OxygenOS 10.0.14 and 10.3.6 [India] for the OnePlus 7T
  1. U1582994955393
    Cupcake Oct 31, 2020
  2. abhishekkapoor81
    Eclair Oct 31, 2020
  3. abhishekkapoor81
    Eclair Oct 31, 2020
  4. C1583671009220
    C1583671009220 , Oct 31, 2020 :
    Their is issue with the phone ringtone after a first ring volume of ringtone decreased automatically . Does anyone face this issue?
  5. MohanTagore
  6. iamsobasak
    iamsobasak , via OnePlus 7T , Oct 31, 2020 :
    I am also facing the same problem
  7. Varyan
    Gingerbread Oct 31, 2020
    Varyan , via OnePlus 7T Frosted Silver , Oct 31, 2020 :
    It's not an issue. It is a new feature introduced by oneplus. Once you picked up your phone while ringing it will automatically reduce it's volume. You can turn it off in settings.
  8. bprrkl
  9. ArjunDhare
  10. bprrkl
  11. NarasimhaMurthyK
    Donut Oct 31, 2020
    NarasimhaMurthyK , Oct 31, 2020 :
    Received the update today (India). After installing I have observed battery drain issue. Found that Bluetooth Scanning under Location option is getting ON automatically once the phone is locked even after disabling it. Has anyone observed this issue.
    Further, installed open beta 9 and the issue is not there. I feel open beta is having less bugs than so called "stable" update.
  12. F1603891153023
  13. Tricolour
    Froyo Oct 31, 2020
    Tricolour , via OnePlus 7T , Oct 31, 2020 :
    Its a feature. Open 'call button'. Click on 'three dots' on top right corner. Click on 'setting' then 'sound & vibration'.
  14. JvdBeemt
    Ice Cream Sandwich Oct 31, 2020
    JvdBeemt , Oct 31, 2020 :
    no idea. I live in the Netherlands and got the update as regular ota when I tested by hand for for updates via settings --> system --> system updates. but it might vary per country.
  15. JvdBeemt
    I did a quick check and the OnePlus website does still indicate the 10.0.12 version so I suggest trying the system update function in settings. Who knows, you might get lucky just as i did.
    And still no problems encounterd and normal battery live is fine. In normal usage with screen time of 9 hours or so I manage about 2 days on a full load.
  16. GOKUL SURYA SELVARAJ
  17. Dishank_Sharma
    Dishank_Sharma , Oct 31, 2020 :
    Just hate the new fonts which are come in the latest update in one plus 7T 10.3.6.HD65AA. we even cannot change this fonts which look so unfamiliar and worst.
    Hate this new update.
